spark retard in relation to IAT2 temps
Steve,
The Borderline Knock tables were SCT first recommendation but it didn't work for locking the timing. In other words so it would be WYSIWYG with what the Advantage software showed. Exceeding the timing was not the problem in warm temps with my truck. It was pulling timing.
FYI, SCT would rather you run the one tune the way it comes out and only worry about the MAF tranfer and A/F. At least that was the attitude of the guy we were dealing with.
Originally Posted by LTNBOLT
Steve,
The original tune I got from SCT had the timing ramped too high in the borderline knock table and my truck detonated bad. I changed the spark in the borderline knock and it was fixed.
Interesting that the SCT rep. told you not to worry about the other parameters. I deal with Ryan and Bryan from SCT and they know that I had to change my spark parameters for our crappy CA 91 octane. They had no problem with that. As a matter of fact, they gave me some info. on torque converter lockup changes, intercooler turn on changes, and a variety of other things I could change.
Your right about the maf transfer and a/f, it's essential to get those right.
Steve
Steve,
This was not Ryan or Bryan. The guy didn't say don't worry about the other parameters. It was the attitude that this is the way the software is setup and you wanting to command the timing the software shows on the screen is just not right (so to speak). I'm not the one calling SCT. It's my dyno shop. They know more about Cobras than Lightnings but they are learning fast.
I know the Max Allowed table had to be involved in getting the 18 degrees of timing from 1250 rpm to redline for the race tune.
Leaving the timing to move around on it's own is a recipe for disaster. I have a feeling it would have seen 19 degrees of timing when the ambient temp hit the the low 50's or upper 40's. This would be the temps where I wouldn't want it to see more than 16 degrees.
Do yourself a favor and lock the timing with the Max Allowable Spark Table. I have a 16 degree slope timing tune for the winter, 18 slope timing tune for the warm weather and 18 degree no slope timing race tune. No monkey motion in these tunes no thanks to SCT.
The maximum spark timing allowed is the least of any of the available tables under most circumstances.
DO NOT ignore IAT2 when determining spark! Either you'll risk detonation or set your base spark too low and lose performance.
I didn't just pull this out of my a$$. I have been datalogging this truck for years using many different tunes and I have a stack of timeslips that would choke a mule. I've done more than my share of homework on what works and what doesn't work.
I know the theory of a cooler charge should allow you to add timing hence the intercooler and that's how the SCT and Chipmaster software act much like the stock tuning. That's all fine and well with a stock truck at low boost and low factory timing.
The reality of it on a boosted up L with advanced timing is quite different. In the hot weather the air is thinner producing less boost. The temps will be higher after the intercooler but the lower boost more than offsets this allowing more timing to be added. When it gets cold and you suddenly have 2 extra pounds of boost from the weather if you're running the warm weather tune get ready for some detonation at the top of second gear with it getting worse in Drive. This happens with a locked down tune like the old Superchips programs. What do think is going to happen with a program trying to add more timing when the IAT2 reads cooler? BOOM!!! How many times have we read about this happening when it get cold.
With all this being said you could run a tune that is dialed back enough to be fine in cold weather but it will run like a turd in the heat. We won't get into how much this will cost you at the track.
When I see timing tables on the software screen and I get totally different values when datalogging that makes me uneasy. I was checking my IAT2 temps, intercooler operation and several other things just to find out everything was working properly.
LTNBOLT,
Has the max allowed table worked for you? It doesn't for me in all cases, I've still seen more than what I put in as max allowed in certain cases.
As far as the adding timing in cold weather, you can zero that section of the table out if you want so no timing is ever added due to air temp. I would not recommend reducing or eliminating the timing retard due to high temps just to make sure you get as much timing as you want. That is a safety issue and a guy may run into detonation. Better to fix the air temps than eliminate the retarding of the timing when the IAT2 exceeds 150 degrees.
There is also a spark adder table in regards to A/F; on the stock 03 tune any richer than 11.7 would start adding timing, more the richer it got. They also have a spark adder for A/F to change the max allowed, which would override your max allowed table.
I would really like the story on the max allowed table. If it's truly max allowed then you could limit your max timing there and never have the cold weather problems, as long as you don't allow the other tables to override it.
Jody
Jody
Some modified trucks have detonation in the summer but not the winter and some have it in the winter but not the summer. This is a tuning issue (tables and adders), not a strategy issue.
Don't expect to see your timing match the tables, you'll be disappointed. You'll need to monitor many tables and other parameters to determine the full spark picture.
Originally Posted by camcojb
LTNBOLT,
(Zeroing those tables was the first thing that was tried. The problem was the tune pulling timing. IAT2 was not the issue. I've never seen 150 degrees. The max I've ever seen was 145 degrees and that was with the Eaton after chopping the throttle.)
(Again it was pulling timing and never getting to the level shown in the Tune.)
(Before it was all over to make the 18 degree race tune stay at a fixed 18 degrees from 1250 rpm to redline the tables you mentioned were zeroed. The borderline spark table and max allowed table had the same values of timing 18 degrees from 1250 up. This was not done by us playing with settings. The tune was either emailed back to SCT or changes were made at SCT's request.)
Jody
Jody
Mine is a CUX2. I don't think it's as user friendly as newer programs. I'm not using the Pro Racer Package. This is a tuner that has the full meal deal. I was just looking over their shoulder when changes were being made or where they veiwed changes made by SCT. They made it happen but it didn't go quietly.
When I was running a RWTD Diablo tune it pulled 1 degree of timing for no good reason. It was in the mid 60's outside and IAT1 & 2 were plenty cool. James couldn't believe it. He finally locked it down to get the timing we were after.
This truck is one of those factory freaks that loves timing. It feels completely flat if it doesn't have 2 degrees more timing than the average L needs for the same mods.
. . . Some of the motors that go BOOM break rods but show zero signs of detonation. . .
