? for kb guys
Old Jun 21, 2005 | 11:37 AM
svtsilverback's Avatar
? for kb guys
how do you think the following combo would perform (hp/tq and 1/4)
kb 14psi,cai,c@l inlet tube,bassani cat midpipe,magnaflow catback with a dyno tune.
Old Jun 21, 2005 | 12:49 PM
2bscrewed's Avatar
12.20's on Nitto's. At least that's what mine did in the heat with that set-up with slappers at FFW Richmond last year.
Old Jun 21, 2005 | 02:28 PM
Casey02L's Avatar
450/550 or so pretty safely with a good tune. You really sure look at doing injectors and MAF at the same time
Old Jun 21, 2005 | 02:32 PM
35thPony's Avatar
No need for injectors... You will need and SCT BAF2400 and 255's.... Casey is real close in the numbers I think and 2b on the times...
I wasn't maxing out my injectors with 16.5# of KB at 477 rwhp...
Old Jun 21, 2005 | 04:26 PM
Casey02L's Avatar
I'd do the injectors before the pumps. I've seen the pumps doing fine in the 500 and above range, but injectors are maxed around 450 which you don't want them at max or close to it. You don't really want to run the injectors past about 80%
