Which Cherry Wet Wax ?
Old Jun 20, 2005 | 08:51 AM
LouScrew's Avatar
I have been using Zaino for years and I like the results, but I live outside of Houston and with the high humidity I sometimes don't have the time to wax and let it dry properly. I heard people here say that Cherry Wet Wax does a great job and drys quickly. I did a google search and came up with a few makers of Cherry WetWax. Which one do I buy? Some of the makers are Coats, Gord's,k-chemicals,chemical-guys. Thanks for your input - LouScrew
Old Jun 20, 2005 | 09:37 AM
litnfast's Avatar
http://www.coatsproducts.com/
Old Jun 20, 2005 | 09:45 AM
got hp's Avatar
cherry wet gives a higher gloss than Zaino but doesn't last past 10 car washes. Easy on and easy off but do not get it ANYWHERE near your plastics (bed caps, cowl cover, etc) or you will never get that white stuff off.
I went back to Zaino because it lasts much longer. Cherry wet is the bomb if you are one who likes to wax once a month
Old Jun 20, 2005 | 10:06 AM
brain bypass's Avatar
are you using zfx? i live in houston, and my coats dry in loke 20 minutes. maybe you are putting it on too thick?
i put a coat on, go inside get somehting cold to drink, go out side *** sonn as i cool off and stop sweating, and it is almost always dry.
there may be some products that give a little more shine, but the durability of zaino is hard to beat.
Old Jun 20, 2005 | 10:19 AM
LouScrew's Avatar
Brain- I have not used ZFX. I have used Z-1 Lok with Z-2 and Z-5. I may be putting it on a little thick but on the humid days when I lightly coat my truck, it seems to take two or three hours to cure. Maybe I need to try ZFX with the Z2. I am please with the look and last of Zaino. My only problem is having to set aside too much time waiting for it to dry.
Old Jun 20, 2005 | 10:45 AM
Harley#356's Avatar
ZFX is the key. i dont even know why zaino even still sells Z1. there's no point to even doing it the old fashion way and waiting forever like that.
it can get humid as hell around here in the summer, up to 100% humidity often times, and i can still wipe off the zaino when using zfx by the time i'm done applying it to the truck. can go right back to where i started and begin wiping it off
and i've also heard the same thing about CWW...looks nice but durability definately lacks
Old Jun 20, 2005 | 10:49 AM
got hp's Avatar
man I haven't used Z-1 since 01! You definately need to get some ZFX!
yeah, definately try it with zfx before anything else.
