Fuel Pressure?
Old Jun 18, 2005 | 10:48 PM
mac02lightning's Avatar
Fuel Pressure?
Does anyone have a problem with fuel pressure after installing SCT 2400 mas air, 60 lb injectors, and a custom calibrated SCT chip? With stock fuel rails and a custom fuel system. Any info would be greatly appreciated. Thanks
Old Jun 19, 2005 | 01:09 AM
Casey02L's Avatar
It shouldn't change with those mods unless you are over 500HP and running out of fuel pumps, or over 600HP and running out of fuel system period.
Old Jun 19, 2005 | 10:44 PM
I'v got two walbro 255 fuel pumps. Might be my stock rails? Do you still run your stock rails?
Old Jun 19, 2005 | 10:56 PM
Casey02L's Avatar
Stock rails here.
What kindof problem are you having?
Old Jun 20, 2005 | 01:08 AM
lightninquick's Avatar
i have about the same set up and the only problem i have is that the fuel filter gets plugged alot more often now
Old Jun 20, 2005 | 11:08 AM
Casey02L's Avatar
A clogged fuel filter is more of an issue of the gas you put in the tank than the mods. Yes you are moving more fuel, but if it was clean then it should not be a problem.
Although the factory filter is very small and will clog easily.
Old Jun 23, 2005 | 01:44 PM
No Problem
Stock rails here.
I'm finding out any info about this before I proceed to put on the truck. Another L has a problem with the same mod's and I want to make sure before putting on that I'm not going to have the same problem. Thanks for the info I appreciate it. Mac02lightning
Old Jun 23, 2005 | 01:48 PM
promodlightning's Avatar
Remember "you are the chosen one" Mac...
