Help with a Sick L
Old Jun 17, 2005 | 11:27 AM
TheGoaT's Avatar
Help with a Sick L
Help identify these noises from a Sick L:
http://tidewaterlightning.com/SickL.WMV
Old Jun 17, 2005 | 11:37 AM
CSHEETS's Avatar
Damn Goat that sound bad. Do you want me to look at it for you?
Chad
Old Jun 17, 2005 | 11:39 AM
TheGoaT's Avatar
Chad, I could use all the help I can get. I dont know who in our area would be knowledgeable enough to take it too.
Old Jun 17, 2005 | 11:48 AM
ZorPrime's Avatar
could possibly be the fuel pump. Thats the same exact thing mine was doing when the hose came off in the tank and the pump went poof.
Old Jun 17, 2005 | 11:55 AM
TheGoaT's Avatar
really? Thats something to think about I suppose. Although the noise sounds like its coming from the engine.
Old Jun 17, 2005 | 12:20 PM
ZorPrime's Avatar
youd be suprised at all the noise the motor makes when its starving for fuel.
Dunno if that is your problem for sure, just some possibilities
Old Jun 17, 2005 | 01:03 PM
LatemodelRacer2's Avatar
idler going bad maybee? Mine made that noise when it was locking up. take the belt of and see if the noise is still there.
Old Jun 17, 2005 | 03:50 PM
tallimeca's Avatar
wow
that sucks man.
Did you check to see if you have an codes?
Sounds like you could have a major vacuum leak or intake leak.
Either that or something with the timming is off.......like a timming chain tensioner puked and it may have jumped cam timming.
Or maybe you burnt up a valve.
Did it start doing it while you were driving? What were you doing when it happened?
Would putting a fuel pressure guage on it tell you if the lines in the tank came off rather than pulling the tank apart to find out it's fine.??
Good luck. Nothing worse than having problems with you pride and joy.
Old Jun 17, 2005 | 04:02 PM
Slick_Sammy's Avatar
sounds like you sucked up one of those cheasapeake crabs while street racing over the bridge tunnel
that thing has got to be throwing some codes ? good luck
Old Jun 17, 2005 | 04:18 PM
booboo454's Avatar
That's how my L sound at idle everytime I pop a plug.
Old Jun 18, 2005 | 12:58 PM
TheGoaT's Avatar
well got the last plug out finally, it really didnt want to come out. In total there were 3 melted plugs, 2 on the front passenger side, and 1 on the front drivers side. Im most worried about the one on the drivers side as half of it was gone. Pics arent the best but bare with me:
Old Jun 18, 2005 | 01:27 PM
ShockTherapy's Avatar
I replied on nloc
