What idle for cams?
Old Jun 14, 2005 | 06:20 PM
Casey02L's Avatar
What idle for cams?
What is everybody getting there idle set at for cams? Just got my new motor installed, and it sure won't idle with the cams. I was guessing about 750~800???
Old Jun 14, 2005 | 07:35 PM
cpeapea's Avatar
i think mine idles around 800ish, it seems to idle good but lumpy. i remember it took a few minutes for the pcm to learn the cams
Old Jun 14, 2005 | 07:37 PM
camcojb's Avatar
I've been as low as 650 rpms but it's happiest in the 750-775 rpm range on mine.
Jody
Old Jun 14, 2005 | 07:46 PM
Suavy's Avatar
I'm running 1000 with Crower stage 3's
Peace,
Suavy
Old Jun 14, 2005 | 09:24 PM
LightninMike's Avatar
mine doesnt want to idle when its in gear but in park its about 800 to 950 i guess
Old Jun 15, 2005 | 01:19 AM
Suavy's Avatar
Mike, Make sure your IAC valve is good and clean. Your truck has been sitting while your engine was getting built.
Peace,
Suavy
Old Jun 15, 2005 | 07:45 AM
CSHEETS's Avatar
Mine idles around 850 or so with stage 3 cams.
Old Jun 15, 2005 | 08:59 AM
35thPony's Avatar
Stage II cams, 775 for me.
Old Jun 15, 2005 | 10:49 AM
Peace,
Suavy
cleaned out its all good i have now moved on the the vac lines
Old Jun 15, 2005 | 11:29 AM
JimIII@jdm's Avatar
Former Sponsor
a smooth 750 in Park, 800 in Drive.... JDM Ported heads and cams
JimIII
Old Jun 15, 2005 | 11:49 AM
cfi_luz's Avatar
Banned for Multiple Accounts
I have comp stage III cams. Tried 750 for idle and it would die all the time, after about 2 weeks the PCM finally seems to have learned the routine. Although it doesn't die now, when you go from D to P it will drop down to ~500 and almost die and barely catch and then idle at 750. I will probably raise it back up to 800 as it had no problem when set there. Remember if its a new motor and the battery was disconnected it will take some time to get the idle strategy worked out in the PCM.
