Lucas octane booster
Old Jun 14, 2005 | 12:46 AM
sonic blue l's Avatar
I know most of the octane booster out there doesn't do much or anything but does anyone know anything about this stuff?
Thanks.
http://www.lucasoil.com/products/index.sd
Old Jun 14, 2005 | 12:55 AM
l-menace's Avatar
remember if it raises the octane by 5 points (which is alot), that in reality means it goes from 93 octane to 93.5 octane.
Try a search for toulene or zylene
Old Jun 14, 2005 | 01:02 AM
I've seen the info on mixing that and marvel mystery oil (cant find that anywhere, maybe not avail in Canada?) with fuel.
I only have 91 available and was thinking of going from a 2# to a 4# but was not sure it that was the best idea with only 91? I thought this lucas stuff might just give a bit more insurace with the 91.
Old Jun 14, 2005 | 10:48 AM
usaf_eagle's Avatar
10 points = 1 octane I have yet to see an autozone "octane booster" that actually does any good.. so paying $4-5 for 1 octane is a RIP-OFF.. plus extra octane doesnt do any good unless you've got a tune to support it..
There is some stuff called "off-street legal" i think which raises you 20 points or 2 octane.. thats enough to raise your timing 1-2 degrees..
Old Jun 14, 2005 | 01:27 PM
LIGHTNINROD's Avatar
This work's ---over-the-counter 'boosters' don't. Yes, that costs more but it works as advertised. I used it at the track religiously. .
Dan
Old Jun 14, 2005 | 01:56 PM
l-menace's Avatar
http://www.team.net/sol/tech/octane_b.html
https://www.f150online.com/forums/sh...hreadid=157558
Old Jun 14, 2005 | 02:03 PM
usaf_eagle's Avatar
Dan
Torco's good stuff.. im with lightninrod on that one..
Old Jun 15, 2005 | 02:48 AM
don presby's Avatar
sonic blue l !!! Marval mystery oil & Valvoline type FA trans fluid are yhe same. I always have Toluene in my gas, and have used both with no trouble.
Old Jun 15, 2005 | 04:09 AM
Sharpshooter's Avatar
Dan
How many gallons can you mix it with?
Old Jun 15, 2005 | 04:13 AM
svtpete's Avatar
If ever decide to use toulene in my truck at the track, will i need to wory about air/fuel or timing?
Old Jun 15, 2005 | 02:26 PM
l-menace's Avatar
nope.,
I run it once in the spring when I pull the truck out of storage and when I go to the track.
I also run it through my grand cherokee once in a while to clean out the fuel system
Old Jun 15, 2005 | 02:56 PM
SVT_KY's Avatar
Torco Rulz for conveinence.
Toulene is harmless in less than 40 percent
mixes. And it REALLY cleans things up !!!
Old Jun 15, 2005 | 06:40 PM
Smoak's Avatar
Do NOT use it. I tried that exact brand and it killed my plugs
Old Jun 15, 2005 | 10:59 PM
thanks for the info
Btw - dont use what?
