Front Skinnies
Old Jun 3, 2005 | 04:05 AM
afchad's Avatar
Front Skinnies
What kind of front runners (or skinnies) is everyone running. I have AR Baja's in the rear and am looking for some for the front
NOTE: Don't want 15"....do not want to shave calipers
Old Jun 3, 2005 | 10:27 AM
Kevs-svt's Avatar
I just run our spare tires they are only 7 inches wide and alot lighter than our stock wheels. I belive they have a SR speed rating.
Old Jun 3, 2005 | 01:05 PM
mhays26's Avatar
235/60/16
Old Jun 3, 2005 | 01:47 PM
JeffsLightning's Avatar
195/80SR16.. 94 bucks... tread is 4.8" overall diam. 28.2 weighs 20lbs. Just about the same diameter as stock... Not to mention it can carry the weight of our front ends...Anyone ever see what Mickey Thompson or Hoosier says about their weight maximums on their front runners..
Old Jun 3, 2005 | 02:27 PM
Casey02L's Avatar
http://www.nloc.net/forum/showthread...ighlight=eagle
I'm pretty sure that guy still has them
Old Jun 3, 2005 | 03:28 PM
brain bypass's Avatar
these?
http://productcat.bridgestonetire.co.../pp_334139.pdf
Old Jun 3, 2005 | 03:37 PM
BigBobsL's Avatar
http://www.svt-enthusiast.com/module...ags/01011035_G
Here is a picture of the 16" front runner you are wanting, while not cheap, this 16" tire AND rim weigh 24# and are 27.5" tall and require no grinding! I spec'd the first four (and to date, probably only four) 16" front runners they have built. Perfect compliment for my 16" x 11" rear wheels. My friend PitchBlack has the other set.
Old Jun 3, 2005 | 03:56 PM
Ct.TOPGUN's Avatar
Nice find BigBobsL. What size rims are you running with them?
Old Jun 3, 2005 | 04:06 PM
BigBobsL's Avatar
16" x 5" front skinny rims and 4-1/2" tread width tires.
Old Jun 3, 2005 | 04:07 PM
Any idea on the weight capacity of that tire?
Old Jun 3, 2005 | 04:09 PM
mike00L's Avatar
I have A/R Baha's in all four corners, I think they look pretty cool although they arent the lightest wheels available for the Lightnings. 16x8 on the fronts
Old Jun 3, 2005 | 04:12 PM
BigBobsL's Avatar
Sorry, these are true front runners, since they are designed for minimum weight, this tire and wheel combo are track only items. Neither are designed for street use unless it is a 1/4 mile at a time with no potholes or high speed corners.
Old Jun 3, 2005 | 04:16 PM
Sorry, at that weight, the tire and wheel are track only items. Neither are designed for street use unless it is a 1/4 mile at a time with no potholes or high speed corners.
That is the problem I was having with Hoosiers or MT's...750lb weight capacity scared me even if only at the track... quote per Hoosier"750 lbs of load at 35psi. per tire
Thanks.
Steve Hudspeth, Hoosier Racing Tire"
Thanks for the info...
Old Jun 3, 2005 | 04:21 PM
BigBobsL's Avatar
Thanks.
I am out of the country right now, but certain front tire capacity is at or more than 1000 lb, but still a good bit below true load. Generally run 40 psi pressure.
Old Jun 3, 2005 | 05:16 PM
does anybody make a 16x6" rim in the 5x135mm pattern? for a reasonable price?
