How to remove balancer pulley?? (not s/c pulley)
Old Jun 2, 2005 | 09:25 AM
halcyon's Avatar
I lost my Haynes manual and was wondering if there is any trick to removing the balancer pulley....
Its a long story, but I need to replace the one thats on there right now.
Old Jun 2, 2005 | 12:34 PM
meansvt00's Avatar
by balancer i suppose you mean the harmonic balancer if so you need to get a puller to remove it. it can be purchased at most auto parts stores or sears but thats the only way your gonna get it off
Old Jun 2, 2005 | 12:54 PM
halcyon's Avatar
damn, is there room to use a puller?
Old Jun 2, 2005 | 01:16 PM
Herb101's Avatar
I just saw a post on an unrelated forum (about 476-54 AD Chevy Trucks) about a puller bieng modified to allow for tight clearnaces. Essentially, the guy cut down the threaded shaft and gound a new tip on it to accept the removable point. Just make sure the puller has enought length for the required pull 'stroke'. You could pickup a cheap puller at an auto parts place or a flea market to give this a whirl. You may still need to pull the radiator for clearance, but I doubt it, if you mod a puller.
Herb
Old Jun 2, 2005 | 01:37 PM
halcyon's Avatar
I've never done this before, what holds the pully on so damn tight?
Old Jun 2, 2005 | 04:28 PM
l-menace's Avatar
cr@p,
Wasn't I supposed to take pictures of mine for you?
Old Jun 2, 2005 | 07:03 PM
meansvt00's Avatar
its pressed on to the shaft. there is an installer tool also which is just a long threaded rod and a nut. i know some just zip it on with the bolt that holds it. not the correct way but it works.
Old Jun 2, 2005 | 07:16 PM
Herb101's Avatar
Here's a shot of the guys 'modified' puller:
BTW, the installer is a bit more than a threaded rod and a nut, but not by much. There is also a roller bearing that contacts the threaded rod bolt head (under a washer) and the face of the balance. The bearing prevents galling and supposedly more evenly distibutes the load.
Herb
Old Jun 2, 2005 | 07:31 PM
meansvt00's Avatar
Herb
^what he said^
Old Jun 3, 2005 | 12:04 AM
LightninMike's Avatar
i have used the installer and it was ****ty
i just got a longer bolt and did it that way
