Mike Troyer does it again!!!
Old May 26, 2005 | 09:59 PM
Cub Cadet's Avatar
Smile Mike Troyer does it again!!!
I ran the Lightning at the annual Norwalk Smackdown today, and the truck responded very well. The 2002 Lightning ran a best of 12.42 @ 109.5 mph and had a 60' of 1.91 ON F1's. The truck has a 6# lower, 2# upper and Troyer tune.... absolutely a phenomenal beast. Air fuel is still conservative, and I run on 94 octane. The weather was 68 deg, and the humidity was a factor all day. Thumbs up the Mike Troyer and his people at Troyer Performance! THANKS!!!
Old May 26, 2005 | 11:21 PM
Marc Carpenter's Avatar
Sounds good Cub Cadet. Since we both use Mike as a tuner, we should try to meet up sometime. Where do you normally run ??
Old May 27, 2005 | 12:57 AM
afchad's Avatar
Cub Cadet...you ran a 12.4 @109 and your only mods are a 6# lower and 2# upper and a tune
Old May 27, 2005 | 01:03 AM
This is the same set up I had on my '01 Lightning that Mike Troyer tuned and it went 12.39 @112. Identical mods.....
Old May 27, 2005 | 07:20 AM
ByByBird's Avatar
Nice times for an unported blower spinning that fast
Old May 27, 2005 | 07:44 AM
Blown93's Avatar
congrads, nice run..........
PEacE....................
Old May 27, 2005 | 11:59 AM
NTIMD8's Avatar
I dont see why not. I ran 12.6@107mph with just a 6# lower, airintake and Mail order chip from JLP.
Old May 27, 2005 | 05:14 PM
WA 2 FST's Avatar
Yeah the times do not surprise me.
My virgin trip to the strip netted 12.8 @ 109 w/ 4# lower, CAI ,Magnaflow cat-back + Troyer SCT9100 93 octane tune as my only mods.
Old May 27, 2005 | 06:31 PM
Blown347Hatch's Avatar
Does everybody's truck here have tailgate, both stock seats, spare tire & jack, and hitch?
If yes, y'all are haulin a$$ with very few mods.
Old May 27, 2005 | 07:35 PM
Cub Cadet's Avatar
Marc Carpenter - It's me - Phil
I made all the passes with the pass. seat in, the tailgate on, and the bed cover on. Gone are the hitch, sway bar, spare, wipers, and washer bottle.
The truck does have the following list of overall modifications:
AirForce One filter kit, BaBolt Throttlebody, NGK TR6's, Magnaflow exhaust and Lakewood traction bars.
All I need are a set of Hoosiers, and I believe this truck to be at least a 12.20 ride in good air.
Old May 27, 2005 | 08:46 PM
What State are you in? I know down here in So. Florida the heat/humidity is kicking, especially nowadays. I would say we (and probably most others would be) are a little slower due to the crappy air?
Old May 27, 2005 | 09:38 PM
NCsvt2003L's Avatar
Ran a 12.43 with a #4 lower.
Old May 28, 2005 | 12:26 AM
Slick_Sammy's Avatar
Dayum I've got to get down to Bristol to see what I run in the quarter. i laid down a 8.17 1/8th mile on a 1.91 60' w/F1s after my new Troyer tune and i am happy with that. What does that equate to in the quarter mile fellas? Does the 1.56 x 1/8th ET = 1/4 ET hold true? or is it 1.58.
I pull my swaybar, spare, jack, & subwoofer.
Old May 28, 2005 | 01:06 AM
NTIMD8's Avatar
Mine had all of that still on. I didnt even take out the spare tire. Drove to the track, pulled up to the line and ran mid 12's all day long. It would varry from day to day depending on weather but I usually ran between 12.6 and 12.8.
Old May 28, 2005 | 05:56 PM
WA 2 FST's Avatar
I do not have the hitch. I took that off b/c I do not tow anything with my truck. But everything else is stock, including a couple of subwoofers and large amps inside the cabin. I've got a soft tonneau cover... not sure if that helps aerodyamics much or not (manufacturer claims notwithstanding).
