Methanol injection???
Originally Posted by Blown347Hatch
I logged several runs (blasts) leaving the track that night. Each time, at WOT the Predator was glued to 21 degrees. I am sure where the timing was.
Timing has very little effect on A/F. I don't believe that three degrees threw my A/F ratios so far out of whack that I didn't pick up any ET because of that....
Originally Posted by Casey02L
Different tune could have a different A/F set in it.
Just to clarify, it was the same exact tune I've used every time I've been to the track, except this time I added three (3) degrees globally, therefore, it was the same tune with 21 degrees timing (instead of 18).
My truck doesn't seem to gain much beyond 18 degrees WOT from my own track testing. I've seen dyno tests where each degree is only a couple HP.
Looks like my truck is one of these.....
We are getting ready to install the Stage II kit on an 01 (based on MAF). We have done a lot of Dyno tuning on it already, so we have a solid baseline to compare to. At the 600 HP level you need to go with the Dual Nozzle set up.
It will be interesting to see what impact it has on the tune and AFR. His plan is to install an inline switch and only turn on the Boost Cooler when he switches to his race tune, (X-Cal I) and not change fuels. Now he has to drain his 92 and use 103 before hitting the track. I would be happy to share the results with the board once completed.
Next week we are also doing a 91 Typhoon. He will be using the Variable Contoller that triggers off of boost. (0-38).
Ron
PS..the recommended mix is 50/50 for the gasoline applications, so make sure you have the correct content in the window washer fluid.
Ron
I do not have the dual nozzle and have no plans to add it. With the larger nozzle I already have enough alky to change my a/f over 1 full point. Also, on my truck I run 100% denatured alky, no water. When I add water I get a stumbling at the lower areas like getting on the freeway; right where the boost/airflow is enough to trigger but the throttle isn't opened much.
Jody
Jody
Have been following the thread...is this what you guys are talking about?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
RR
RR
Yup; that is it!
RR
RR
sorry to bring up an old topic here, but i've been looking into this recently. I have heard of some running actual washer fluid instead of methanol. Is this ok? It seems like it doesn't get much cheaper than washer fluid...
You can run that Jim, as it's just a mix of alcohol and water (along with some dye). Problem is that in warm areas like yours there is mostly water and only a small percentage of alcohol, as there's very little freezing danger. If you could get some from a snow area it would be a much higher mix of alky to water.
Also, mine stumbles at high load, light throttle areas with water mixed in (like passing on the freeway without downshifting, climbing a hill, getting on the freeway). I run straight alky because of this.
Jody
We have never installed one on that specific combo, but you might read this thread on NLOC for our results. http://www.nloc.net/forum/showthread...light=methanol
