Predator Revision/MAF
Old May 15, 2005 | 12:25 PM
rheagrimm's Avatar
Question Predator Revision/MAF
Previously I tried using a 95mm MAF tube and got a lean code. If what I have been reading is correct or if I understood it correctly, with the Predator revision I should be able to richen the MAF fuel curve or add fuel and be able to use the larger MAF tube. Is this correct?
Old May 15, 2005 | 02:27 PM
camcojb's Avatar
Although it's possible I'd say it's doubtful. Generally it requires a complete new maf transfer in the tune to compensate for the different MAF's. Any tuner should get you going close enough to be able to fine-tune it with the Predator.
Jody
