High flow shot?
Old May 14, 2005 | 09:07 AM
Dan SS2471's Avatar
High flow shot?
I noticed a rattling noise earlier this week and narrowed it down to happening when the truck was idling in gear. Today when I got home from a 200 mile road trip the rattle was ever-present but much worse.
I jacked the truck up and had my wife start it. I was directly underneath the passenger side convertor and it was rat, rat, rat ratttling so that's the culprit.
These are Dynatech long tubes and no pre-cats and they were purchased from Razor's Edge. Here's a link to the ones for the Lightning. My invoice has the same part#, however. The site doesn't have a link to the HD ones for some reason.
http://www.razorsedgemotorsports.com...roducts_id=214
Question is.....is it common for a high flow cat to malfunction?.......They were installed in July, '03.
Also, is it ok to drive until I can get it fixed?
I'll get in touch with REM and ask about a warranty. ha ha.
Thanks...
Old May 14, 2005 | 10:36 AM
Don's Bolt's Avatar
The cats and headers for a Lightning are the same as the HD's
You will be fine driving around with it the way it is. I had the same thing happen to my Magnaflow cats. Eventually it stoped making noises, but by then the cat was just a empty shell.
You won't hurt anything driving around like that, it is just annoying.
Old May 14, 2005 | 11:05 AM
Dan SS2471's Avatar
Thanks, Don. I'll get it replaced eventually but it still kinda sucks that a system that's less than two years old is malfunctioning like this.
Old May 14, 2005 | 11:29 AM
Dan SS2471's Avatar
I called Razor's Edge and they need to call Dynatech on Monday to see what the warranty is.
Thanks..
Old May 14, 2005 | 12:29 PM
Sharpshooter's Avatar
I just noticed the same sound. I haven't had a chance to investigate, but most likely its doing the same thing as yours. I also have dynatech's from REM.
Old May 14, 2005 | 12:59 PM
Dan SS2471's Avatar
How old are they? I'll let you know what I find out on Monday. Maybe we have a trend here.......
Old May 14, 2005 | 01:07 PM
I bought them USED from rem in July of last year. I think they told me they were on a customers truck for a few months before I bought them. So they shouldn't be more than a year old.
Old May 14, 2005 | 02:48 PM
Dan SS2471's Avatar
If you don't mind, what's your engine setup? I'm trying to gauge whether temps have anything to do with this. I typically see 1240 - 1260 on my EGT when cruising and 800 - 1100 around town. The truck is putting about 500/625 to the wheels with my current pulley/tune setup.
Thanks..
Old May 14, 2005 | 02:55 PM
Thanks..
Pre-Headers I had ~420RWHP. I don't have a EGT, so I don't have temp readings. I only have a 4# and a Apten. I have only been to the track 3-4 times since I put the headers on. I don't think I have ran any race gas at all since I put the headers on. I will look at the truck some time this week to see if it is auctually the cat that is rattling.
Old May 14, 2005 | 04:10 PM
Dan SS2471's Avatar
Thanks. Hopefully it's just a heat shield or something simple like that.....
Dan
Old May 14, 2005 | 05:49 PM
QWIK HARLEY's Avatar
Dan-what other mods do you have done to get your HD in the 500 hp range?
Old May 14, 2005 | 06:15 PM
Dan SS2471's Avatar
Oh...it's got a built short block, KB and all of the other good stuff. Previous owner did all the work. It put down 525/634 on one of Sal's mild race tunes and some good gas. It's toned down for daily driving now but I have two other uppers and two race programs if I want to turn up the boost and get a little more aggressive.
Old May 14, 2005 | 06:25 PM
Very nice.Just curious did you remove the grill or did the previous owner?
Old May 14, 2005 | 08:01 PM
Dan SS2471's Avatar
Only thing I've done so far is put some new tires on it and some Zaino. Oh yeah..and a new S&B filter.
Old May 14, 2005 | 10:46 PM
can't tell from the pic,but is there a black grill or was the stock grill just removed?
