Turbo GENII 32V almost done.....
The truck just came back from Bassani and John Urist. All that is left is having everything ceramic coated, wiring harnesses and sensors installed, and fuel system installation. Tuning will commence with the Turbonetics T-78/Q-trim...........
Sweet lookin setup. That T78 is a big one! Keep an eye on you big blue coupler hose. Those things have a problem of ballooning under big boost. I have watched them on the dyno grow by 20%-30% as the boost increases. Makes tuning a little tricky. Should be a beast once you are dialed in. Best of luck. Hope to see the results posted here soon.
Real niiiiiiiiiiiiiiiiiiiiiiiiice set up Bro, Hats off to the workmanship.....
I want a turbo so bad, but after just putting so much new stuff into mine
(I couldn't use anymore), it just doesnt make sense right this second.
Cant wait to see the #'s
Originally Posted by RedSVT01
what are you going to do for a cooling fan. not much room there. looks great though.
-Mat-
