aftermarket cam gear help
Old May 8, 2005 | 10:07 PM
bacamino's Avatar
i was in the process of installing my new crower stage 2 cams. i installed the new cam gears and there is alot of play in the gears even with the bolts installed the gears slide about 3/4 of an inch in and out. this doesn't seem normal to me is there a spacer I'm missing. any info would be greatly appreciated.
thanks
Victor
:tu:
Old May 8, 2005 | 11:40 PM
BigBobsL's Avatar
Yes there is a spacer needed on each cam. I do not have the numbers, you will need to do a search.
Old May 9, 2005 | 06:57 AM
KB ZILLA's Avatar
I just bought the spacers the other day but the part numbers are at home...sorry
They are only like $8
Old May 9, 2005 | 10:17 AM
LightninMike's Avatar
yep spacers are needed
spacer, gear, washer, bolt is how it should go on
i to do not have the part #'s in front of me but i do know razors edge has them as i got my whole setup from him
Old May 9, 2005 | 11:26 AM
bacamino's Avatar
thanks for the info guys i new it wasnt right ill have to get some spacers.
thanks
Victor
