still searching for what is wrong...
Old May 5, 2005 | 08:34 AM
samiam513's Avatar
Question still searching for what is wrong...
My truck has a bad miss at idle, up to around 1750 rpm's. The problem is intermitant. I can get off the interstate, sit at a redlight idleing, and the truck will be fine. I cna drive 20 feet and stop, and it will miss.
I have checked the coils, all are good.
i have replaced the sparkplugs. tr6 gapped at .37. br7 are not in.
I have replaced the IAC. no change.
I checked all vac hoses. All are good
I have unplugged every fuel injector 1 at a time and all make the truck run like crap.
checked the egr. all is fine.
I have run 3 bottles of fuel injector cleaner through the truck
My driver side o2 reads funny. It will read .7,.8,.1,.9,.6,.8,.2,.6,.9
ect... goes low for a split sec, then pops high, then low again a few secs later ect... The computer was throwing a code for o2 bank 1 lean, then it stopped throwing that code and now it throws o2 bank 2 lean, and o2 bank 2 rich. all codes are for sens 1.
the comp is on the stock tune right now.
A poss. i have been presented is a dirty fuel injector not coming clean. I have the price for new stockers and will purchase them if there are no other cheaper troubleshooting tips.
Any ideas?
Old May 5, 2005 | 08:46 AM
typhoon43's Avatar
How many miles on your ride? Any chance you have a bad O2 sensor?
Old May 5, 2005 | 09:33 AM
samiam513's Avatar
24k miles.
Old May 5, 2005 | 09:42 AM
halflife's Avatar
has your timing chain every been removed? I had a miss, did all you did, then Sal pulled off my timing cover and when Ford replace the timing chain after replacing the heads it was off 2 teeth. He fixed it and the miss was gone. did you check the voltage on the coil pacs?
Old May 5, 2005 | 09:44 AM
Blown347Hatch's Avatar
Consider a compression or leak down test?
Old May 5, 2005 | 09:48 AM
samiam513's Avatar
timing chain has never been removed to my knowlege. Truck was used, but it has never missed this baddly.
I have considered both, and am looking for time to do them. But if it were internal, wouldn't it do this across the rpm range?
Old May 5, 2005 | 09:58 AM
TriPodRacing's Avatar
Copper plugs are a great thing......
Try a set of platnium plugs.
Rob_02Lightning's Avatar
If you have not changed your Fuel Filter
DO IT,you may be surprised
Trust me, I know.....
BTW
Doesn't matter how old it is either
Old May 5, 2005 | 11:28 AM
samiam513's Avatar
ttt
