Weird...a consult needed
Old May 1, 2005 | 07:43 PM
wazvette's Avatar
Exclamation Weird...a consult needed
Whats up guys...
My L hesitates at low RPM SOMETIMES (it happens once every 20 minutes of driving I would say...so not very frequent..on turns and driving up hills more I would say...it could be due to down shifting to the low RPM range)...
BUT when at full throttle it flys!!...I thought fuel filter but the L only has 2k miles!..so that couldnt be too bad...plugs?...I just installed TR6s...a 1k ago...this action is not consistant...the rpm quits moving I depress the gas peddle a littile more and it could move or I even need to depress more and then its normal....I even raced a CamaroSS today at WOT and I owned him...NO pinging too...Ill check the fuel filter and plugs...any other areas I should look at? I did my search and some people reported a pulled plug that had to be reconnected ...what plug is that?
My Mods
cold air kit
accufab
6lb lower
long tubes and full exaust
tr6s
level 10 tranny w/2400 stall conv.
Thanks guys
Waz
E fans
Custom JDM chip(no tranny mods on chip)
Old May 1, 2005 | 10:43 PM
wazvette's Avatar
Its doin it more often now....I just went out for a spin...its like the gas peddle has no effect until you give it more gas ......does the MAF has anything to do with it?...cause mine is factory.
I would appreciate any help.
Waz
Old May 1, 2005 | 11:36 PM
Agent00GT's Avatar
It could be the MAF, vacuum leak or any other number of things. Does it miss/skip at ilde? No Check engine light I take it?
Old May 2, 2005 | 12:24 AM
wazvette's Avatar
Yes it vibrates or skips a little at idle....nothing too agressive but its not normal. No check engine
Old May 2, 2005 | 11:10 AM
wydopnthrtl's Avatar
I would suggest a vacuume leak or a faulty TPS.
However, I'd sure think those would throw a SES light?
Rich
Old May 2, 2005 | 01:48 PM
wazvette's Avatar
Dont have an SES light!!...maaaan...ill just take it to a couple of mechanics to check it out....maybe they can come up with something. Thanks guys you are always the best
