Track times
Old May 1, 2005 | 01:48 AM
LatemodelRacer2's Avatar
Track times
Went to the track tonight with the slicks and im dissapointed.
60ft 1.769
330 5.383
594 7.846
1/8 8.396
mph 81.80
This was with a 4lb lower, ported eaton, sct tune by psp along with a few other bolt ons. Does this seem right for my mods i usually run 87-88 mph Almost like the clutches in the tranny are gone
Old May 1, 2005 | 01:59 AM
SlowSVT95's Avatar
I have a 4lb also, minus the ported eaton... on my 12.76 run, my 1/8 was 8.164 and my mph was 85.62. My mphs were low for some reason last night. my 1/4 mph was only 103??
Old May 1, 2005 | 11:51 AM
could anyone that runs the 1/8 with similar mods post there slips. comparing to my old slips it is falling on its face before half track.
Old May 1, 2005 | 12:05 PM
SVT F15O's Avatar
I thought you ran a KB>??? Something DEF does not seem right with those times. When is the last time you put in a new fuel filter>??? -Mat-
Old May 1, 2005 | 12:46 PM
Derek94's Avatar
The other week, w/ the mods in my sig, i went
60ft 1.82
330 5.241
1/8 8.02 @ 87.77 had a few 88's also
1000 10.45
1/4 12.52@ 109.33
Thats w/ mtx thunderform in cab, ******** cover on the bed, NO spare and NO tailgate. I'm going to remove more weight next time out, and im switching to long bars as my 60ft sucks.
Old May 1, 2005 | 01:01 PM
kb locked up and i sold the refunded one
the last time the fuel filter was changed was probley 10k miles ago. but i have a wideband so i know im not leaning out or at least i think.
comparing mine to dereks times it looks like im dieing after the 330 so who knows plugs were pulled today all look good and new went in
the only thing i can think it could be is my wasp port because i only build 14.5lb with a 4lb lower, 1lb upper and the port
Old May 1, 2005 | 02:40 PM
Mickey_shouse's Avatar
Latemodelracer2, What track are u running at if u dont mind me asking? I see ur in Al and as just curious. Ive been thinking bout running a few times at Cherokee pretty soon.
Old May 1, 2005 | 03:43 PM
I went to a local 1/8 called bama. I usually end up at lynn its another 1/8 mile that hooks a lot better than bama
Old May 1, 2005 | 07:20 PM
12leavu's Avatar
the only thing i can think it could be is my wasp port because i only build 14.5lb with a 4lb lower, 1lb upper and the port [/B][/QUOTE]
ok the truck makes 8lbs stock. a 4lb would get you to 12psi. a 1lb upper may get you to 13. it's not winter and your in the south......how much boost do you think it should make??????
Old May 1, 2005 | 07:31 PM
eposey's Avatar
12leave u, where do you get the corners w/o the amber reflectors?
Old May 1, 2005 | 07:35 PM
12leavu's Avatar
i found them on ebay.
Old May 1, 2005 | 07:41 PM
Slick_Sammy's Avatar
do you have a baseline run at this same track to compare your times to? you say you usually go to another track. some tracks are just slow, some fast. one i go to is about 30ft short to make up for elevation so the MPH is way down there but times good.
Old May 1, 2005 | 08:53 PM
ByByBird's Avatar
4# lower, Steigmeier ported blower, tune, plugs, filter, FULL weight and F1s today.
My 1/8 times.
60ft: 1.84
Et: 8.09
Mph: 86.xx
Old May 1, 2005 | 09:35 PM
zx12guy's Avatar
4lb lower, 2.84 upper, WASP ported eaton@14psi, 28x10x16 Hoosiers. dyno'd 417/528
60' 1.83
330' 5.297
1/8 8.177@84.67mph
1/4 12.83@105.50
*note* I was getting sideways on the launch so the truck will def run a faster #
Old May 1, 2005 | 09:38 PM
Ive ran a 8.22 @ 87mph at this same track on stock f1's with a 2.1 60ft
