Would like some opinions...
Old Apr 25, 2005 | 09:18 PM
jordans30's Avatar
Hi all of you,
Well, after reading quite a few posts on these boards, I finally took the plunge today and ordered a few parts for my L (its a 2002 w/ 20K miles, and till this point was completely stock...). Would like some opinions on these:
NGK TR-6 spark plugs
160 deg. thermostat
Motoblue Gen II idler pulleys/bracket
Motoblue Aux. idler
Motoblue HP series CAI
DiabloSport Predator
Accufab polished SB/TB
C&L inlet pipe
6# Motoblue QC Lower w/ Gatorback belt
FTVB with Moroso pan and filter
Bassani cat-back
All parts are going to be installed this weekend. Barring any major problems, I hope to have it up and running Saturday night.
Does anyone have any info about problems i may encounter? I am especially interested in hearing from anyone with a Predator - hope that all the good luck people seem to have had with these doesnt evaporate when i start tinkering with it...Any tips would be sincerely appreciated!
Thanks, and I look forward to your responses!
Old Apr 25, 2005 | 09:23 PM
bglanden's Avatar
Re: Would like some opinions...
Originally posted by jordans30
Hi all of you,
160 deg. thermostat
Motoblue Aux. idler
C&L inlet pipe
Bassani cat-back
Sounds like you bought a lot of RPM mod's. I wouldn't buy the predator from them, unless they can custom tune now. You can purchase the predator from one of the vendor's on here and get a custom tune at probably the same cost!!
Bryan
Old Apr 25, 2005 | 09:31 PM
jordans30's Avatar
bglanden - Yeah, you're right about RPMoutlet....also hit up Chikenears for the FTVB. If I need to, i'll work out the Predator issue after it all comes in... Any opinions on the parts themselves as far as quality (or lack thereof)?
Old Apr 25, 2005 | 09:34 PM
bglanden's Avatar
No problem with part's except I received the wrong belt with the pulley!! Best of luck with the predator, I would do a search on here and pay close attention to all said.
Bryan
Old Apr 25, 2005 | 09:40 PM
birdy111's Avatar
one of rpmoutlet's scams is to send u the wrong belt with your pulley and then charge you s/h to send it back and get the right one... the price is good on the c&l plenum/sbtb package though. I'd shy away from the pulley/filter/chip from them and fork out the little extra to get a custom tune from a tuner because 9/10 have problems with the stock predator pulley tune.
