4lb pulley on the way
Old Apr 20, 2005 | 10:54 PM
onlyfordman's Avatar
I have a 4 lb pulley on the way and already have the superchips micro tuner. Will this run well on a stock 99 L with NO other mods.
Old Apr 20, 2005 | 11:41 PM
wydopnthrtl's Avatar
It'll be the best bang for your buck on a stock truck.
Rich
Old Apr 21, 2005 | 11:05 AM
I'm going to the track Sat. so I will post the results.
Old Apr 21, 2005 | 12:22 PM
With the increased torque down low it'll help to remove the front sway bar and set the rear tires to 26 psi.
I spent a fair amount of time just getting used to re-learning how to launch when I did mine. Unless your track is very very good you'll spin off the line now. Gotta learn how quickly to roll on the throttle.
Try power braking to 800 rpms then rolling quickly to the floor. Adjust the roll speed of your foot depending on how it's hooking.
Rich
Old Apr 21, 2005 | 12:28 PM
brain bypass's Avatar
careful with that combo, it could lead to the temptation of buying more mods to go even faster. i have seen it a hundred times, this is how it all starts.
Old Apr 21, 2005 | 01:32 PM
Kevs-svt's Avatar
It will run great. I have a 99 with a 4#, chip, CAI and with slicks ran a 12.9 my 60' was 1.85 so i know if it wasnt humid i would have run 12.6-12.7 easy. Your next mod sould be a FTVB they are a must. Good luck and have fun.
