Coolant fitting behind water pump
Old Apr 20, 2005 | 03:38 PM
Herb101's Avatar
Does anyone have a proper name or, better yet, a part number for the fitting that goes behind the water pump, through the block, that the coolant hose in the valley connects to?
Or are these fittings re-useable?
My new short block did not come with this fitting and I'm trying to round up all the loose ends for the motor assembly.
Thanks,
Herb
Old Apr 20, 2005 | 04:12 PM
lightninquick's Avatar
i reused mine. no leaks either
Old Apr 20, 2005 | 04:39 PM
Herb101's Avatar
Cool!
Thanks,
Herb
Old Apr 20, 2005 | 05:23 PM
Casey02L's Avatar
How did you get it out? I guess I need to save my old one for my new motor.
Old Apr 20, 2005 | 07:02 PM
Herb101's Avatar
Based on the advice on LightningRodder, I just pulled mine out.
You have to tap it from the valley toward the front of the block. It took some persuasive 'taps', but it came out. It is just wedged in - no O-ring to the block or anything. I'm goint to run a skim coat of Hi-Temp silicone sealer when I re-install.
Herb
Old Apr 20, 2005 | 11:44 PM
Suavy's Avatar
Herb, you are right the are just taped in. There is O-rings on the outer side of the tube for the heater tube.
If you need another one e-mail me I have an extra from my rebuild kit.
Suavy
Old Apr 21, 2005 | 12:21 AM
Herb101's Avatar
Thanks Suavy, but I got mine out without a hitch. Pretty stout little tube there.
Thank you for the offer none-the-less
Herb
