Will JDM cams work with stock program?
Old Apr 20, 2005 | 01:39 PM
AZBLACKMONSOON's Avatar
Just wondering if JDM stage 2 cams will work with stock ECM program , till i get my built motor broke in, heads will have bigger valves and good amount of porting also. How is the idle Quality? thanks.
Old Apr 20, 2005 | 02:04 PM
JimIII@jdm's Avatar
Former Sponsor
It will probably just have some idle issues what I would do for a short term fix is if you have a single blade throttle body open it up a turn to raise the idle.
JimIII
Old Apr 20, 2005 | 02:29 PM
Stl01SVT's Avatar
Get a tune to match your built engine. Even if it is just a mail order tune to start out with.
Old Apr 20, 2005 | 03:09 PM
KCinAZ's Avatar
I think he's just trying to avoid paying for a "break in" tune, and then a full dyno tune after break in.
Old Apr 20, 2005 | 03:34 PM
I want to be able to put a few thousand miles on it before , i put a tune on it, undecided to go with milder Compcam with good idle, or JDM's. Jim my builder may be calling you with some questions his name is Brian Duffee of Duffee Motorsports. Thanks
Old Apr 20, 2005 | 03:35 PM
Whitetrash SVT's Avatar
Really??? That's weak.
Old Apr 20, 2005 | 03:45 PM
White Trash, I live out in the middle of the desert ,between Phoenix and Tucson, 60 miles from anywhere, and do all my own labor ,except machine shop stuff, I have no close by resources and no way of getting my truck to any tuner thats at least 60 miles away. I want the truck to run the first time i fire it up, and have a good break in period, till it's time to turn it up.
Old Apr 20, 2005 | 03:52 PM
It should run great w/ a conservative mail order tune. Make sure you use a reputable tuner and preferably the tuner who would use the same cams you will be running.
