Replacing front swaybar endlinks ????
Old Apr 12, 2005 | 11:38 PM
pitstain's Avatar
when i had my hotchkis installed they obviously overtightened the front links :cr: i was under the truck loosening moving and retightening my stupid bassani's for the 4th time, damm nyc potholes keep making the x-pipe fall off the midpipes.......so i noticed my lower bushings on my front endlinks are well GONE save for a little bit of rubber on the bottom one.....i went to autozone and got the same exact sized set of Energy suspension endlinks that came with the hotchkis setup (9.8119RC), they look simple enough to change but i was wondering if i can just slide under the truck and do it or do i have to jack it up at all, i was hope to just make this a rhinoramp assisted install, like i did for my exhaust, FTVB, oil changes and so on........i appreciate the help, and while your at it churing ouw brain pudding for me could you guys give me an opinion on the new KennyBrown X-Factor chassis brace setup and if it will work with my bassani,.....since nothing else will like traction bars and stuff
Thanks for the help
Old Apr 13, 2005 | 07:19 AM
SVT_KY's Avatar
Yup ... should be a simple unbolt and replace. You can even do
it on a jack and jackstand on a side at a time. I had problems
with the Hotchkiss fitting so I had my buddy weld me up a "offset"
end link ... I gotta picture around here somewhere.
Cliff
EDIT: Here ya go ... I think the offset was exactly an inch
Old Apr 13, 2005 | 09:34 AM
pitstain's Avatar
thanks man, those are sweet links.....but what arms are those? western chassis?
Old Apr 13, 2005 | 02:37 PM
curmudgen's Avatar
If your pipes are falling off, Have you tried some stainless self-tapping sheetmail screws?
1 or 2 per connection should stop them from shaking loose.
Old Apr 13, 2005 | 04:55 PM
SVT_KY's Avatar
Ayup ... Beefy, eh?
and DJM uppers ... of course ...
The way to fix the Bassani's is the TIG welder ... I lost mine
THREE FREAKING TIMES til I fixed it for GOOD !!!
Old Apr 13, 2005 | 05:07 PM
pitstain's Avatar
well the bassanis might be going byebye, i want that x-factor chassis brace from kenny brown and i really dont think it will fit with bassanis, time for a di/do magnaflow system
Old Apr 13, 2005 | 09:50 PM
SVT_KY's Avatar
I think the jury's still out on the X-Factor ... Seems like it's
a bit flimsy for my taste ... Don't know how much that small
diameter can resist the torque that we produce
Old Apr 13, 2005 | 10:01 PM
pitstain's Avatar
it doesnt have to be that thick.... and these chassis need all the help they can get
Old Apr 13, 2005 | 11:35 PM
Tim Skelton's Avatar
Originally posted by SVT_KY
. . . Seems like it's a bit flimsy for my taste ... Don't know how much that small diameter can resist the torque that we produce
The twisting force (torque) that the X-Factor is designed to address has only an indirect relationship to HP. I'm trying it for the torque generated by the F1s in a hard turn. The engine could be shut off.
From my study of the piece, it is designed to transmit loads down the lengths of the tubes. How big do they need to be? Think of all of the chassis stiffeners out there for other cars. They aren't very beefy, nor do they need to be. They just need to be able to keep from crushing end-to-end.
Or something.
Snake oil? Maybe. But chassis stiffeners are universally accepted on other cars. Why not ours?
