Top end gasket kit?
Old Apr 7, 2005 | 12:27 PM
DARE YA's Avatar
Top end gasket kit?
Where do you guys get the kits from? I called my local ford and they want 360 bucks just for the head gaskets. They said its so much because its a lightning...PLEASE HELP ME!!! I need them by this weekend.
Old Apr 7, 2005 | 03:19 PM
LightninMike's Avatar
Re: Top end gasket kit?
nope they are right
you have to buy the gaskets individualy there is no kit
Old Apr 7, 2005 | 03:30 PM
Herb101's Avatar
Do a search - with my user name - for gaskets.
You'll find a complete list of what's reuired for a motor build as far as gaskets and timing parts. Expect MUCH more than just $360 if you are swappinging any timing parts.
Herb
Old Apr 7, 2005 | 05:39 PM
herb
how much did you end up paying for your kit
Old Apr 7, 2005 | 06:15 PM
Herb101's Avatar
I'll add it up and post when I get home. I wound up using three different sources - eBay, FordPartNetwork.com and a SV on ModularFords.
I'll put up some more detail to 'ease the pain' a bit, but it was close to $600 for everything (at least I think and hope it's everything).
Herb
Old Apr 7, 2005 | 07:13 PM
Herb101's Avatar
This group came from FordPartsNetwork, before I found Steve on ModularFords. I have these in hand right now.
4C2Z-6051-BA Head Gasket LH ($65.65)
4C2Z-6051-AA Head Gasket RH ($65.98)
1L3Z-9439-AA Intake Manifold Gasket (x2) ($29.86)
E83Z-9F670-A Idle Air Control Valve Gasket ($0.56)
XL1Z-6L266-AA Timing Chain Tensioner RH ($31.02)
F85Z-6K255-AA Timing Chain Tensioner Arm RH ($12.92)
2L1Z-6M256-AA Timing Chain Guide RH ($12.31)
F85Z-6M274-AA Timing Chain Tensioner Arm LH ($12.92)
XW4Z-6700-AA Front Crank Oil Seal ($8.30)
F6AZ-6840-BA Oil Filter Adapter Gasket ($6.51)
1L3Z-6P250-AA Hydraulic Chain Tensioner Retaining Clip ($11.60)
2L3Z-6584-AA Valve Cover Gasket, LH ($10.05)
2L3Z-6584-BA Valve Cover Gasket, RH ($10.05)
XL3Z-9L437-CA Plenum Gasket ($6.10)
This batch came from Steve on ModularFords.com and total out at about $273. I have ordered these, but not recieved them yet.
F1VY-8255-A Thermostat Housing O-Ring
3L3Z-6710-AA Oil Pan Gasket
F6TZ-6268-AA Timing Chain RH
F642-6L266-CA Timing Chain Tensioner LH
F6TZ-6268-AA Timing Chain LH
XL3Z-6306-AA Crank Sprocket
F4AZ-6701-A Rear Main Oil Seal
F6TZ-9D476-DA EGR Gasket
F81Z-9E936-AA Throttle Body Gasket
1L3Z-9H486-BA Blower Gasket
1L3Z-9461-BA Midplate Gasket
F8AE-6256-BA Cam Gear (L)
F8AE-6256-AA Cam Gear (R)
F1AZ-6278-A (x2) Washer (L/R)
F1AZ-6A340-A (x2) Bolt (L/R)
F3AZ-6256-A (x2) Spacer (L/R)
I picked a set of exhaust manifold gaskets (YC2Z-9448-CA) off eBay for $11, but they list out at $28.80 each x 4
So far - $620 plus one more round of shipping (~$15), but there are a couple thing I didn't need...to the tune of about $25
1) Rear main comes with the new JDM short block
2) tensioner clips are pre-installed on the new tensioners, so I didn't need to order them seperately.
Sorry for the long post, but you wanted the details
Herb
Old Apr 7, 2005 | 07:19 PM
Herb101's Avatar
BTW - this is not all required for the top end - this list is based on a total motor build-up. What you wind up needing will depend on what you yank. Many of the gaskets (INCREDIBILY HIGH QUALITY) appear to be reusable, but I'm not going to gamble with a close to 5 digit investment.
Herb
Old Apr 7, 2005 | 11:23 PM
yeah i paid somthing like 720 for everything i needed
all the gaskets and a new pan and oil filter housing, pick up tube and dip stick and tube
i didnt even think of ebay so you got me there
p.s. if you talked to the same steve i did he is also on svtperformance
i think its tously ford sr something to that effect
Old Apr 8, 2005 | 08:21 AM
Herb101's Avatar
Yeah Mike I think its the same place - in Michigan or Wisconsin or someting like that. I still need to get a pump pick-up, but I got the oil pan on eBay also - used on for $24 including shipping. The brocken rod didn't hole my pan, but it did mangle the baffles in the shallow end. On the pick-up tube, I want to have the short block in hand before I buy, to make sure I get the right one.
BTW - the JDM shortblock came in Wednesday, but its still at my office. I wasn't going to post about it until I got it home and could get some pictures. Looks good through the plastic though!
Herb
Old Apr 8, 2005 | 11:25 AM
yeah my JLP should be in today or tomorrow
still waiting on my heads tho (cams are backed up)
Old Apr 8, 2005 | 12:27 PM
Herb101's Avatar
Whose heads and cams did you go with? I'm thinking between Patriot or LFP - Stage II in either case. I haven't put in the order yet, so the cam availablility may affect that for me.
Thanks,
Herb
Old Apr 9, 2005 | 03:21 AM
i went with the patriot heads and stage 2 cams
when i ordered it was a 2 week backorder on the heads and 3 weeks on the cams
so mine will be here next week
