People useing breathers for the pcv .... i gotta question
Old Apr 4, 2005 | 04:40 PM
Oneevil01's Avatar
I installed 3 breathers on my L when i got it in jan. and blocked off the pcv ..... The truck was bone stock then but now i have a 4lb lower cak and a tune since these mods i am getting a good about of oil blowing out of the breathers ... Do you guys have this problem too ? I am thinking about going back to the pcv setup so i dont have to clean the engine all the time
Old Apr 4, 2005 | 04:53 PM
chesster51's Avatar
I just did the breather mod yesterday and have only been into boost a few times so far, but the filters all still look like they did when I installed them. I know it's still early, but I was expecting to see some oil. How long before you started seeing oil on the filters?
Old Apr 4, 2005 | 05:27 PM
Oneevil01's Avatar
what mods do you have ? Before the mods i lost a 1/4 qt. of oil over say 1200 miles over the last 300 miles i've lost 1/4 qt. witht he mods .... my passenger side cover has got a good bit of oil on it and filler neck breaters was coated bad
Old Apr 4, 2005 | 06:01 PM
chesster51's Avatar
I only have a 4# lower, Bassani catback, K&N drop in with cold air duct running to stock airbox and boost bypass mod.
Old Apr 4, 2005 | 07:04 PM
GRAYONE's Avatar
Same issue here with breathers. I put the pcv system back to stock.
Old Apr 4, 2005 | 09:04 PM
Oneevil01's Avatar
i just did the same today
Old Apr 4, 2005 | 10:01 PM
usaf_eagle's Avatar
3 breathers?? where did you put the 3rd one? and i'd rather clean my engine bay then clean my intercooler... to each his own..
Old Apr 4, 2005 | 10:40 PM
Oneevil01's Avatar
Ya but a 1/4 qt in 2 days ... screw that
Old Apr 4, 2005 | 10:52 PM
Almightywad's Avatar
I have the same coating of oil on the passenger side and the oil filler but I haven't seen a huge drop in oil capacity. I'm sticking with it.
Old Apr 5, 2005 | 03:34 AM
Master Of Pain's Avatar
Did you guys try this method:
https://www.f150online.com/forums/sh...&highlight=PCV
If you did it this way, and you are seeing tons of oil slobber, you may have excessive blow-by. Try switching to a 5-30 oil first, and make sure your PCV's aren't gummed up and stuck wide open. My way allows for effective breathing while retaining oil trap. I'm running a Magnum Powers @ 17 PSI and I get no signifigant oil slobber, however the passenger side filter is beginning to get a little oil-dampened.
Old Apr 5, 2005 | 08:44 AM
chesster51's Avatar
Master of Pain, that is exactly what I did except I also replaced my oil filler cap with a breather type. So far so good.
Old Apr 5, 2005 | 04:01 PM
Patrick_PDX's Avatar
I have a 6lb lower with a ported eaton. Zero oil slobber. None nadda nothing.
If you have ALOT of blowby, you might have a head gasket problem. The head could be lifting when your under alot of boost, thus creating extra pressure in the block and causing the oil to blow out the breathers.
Old Apr 5, 2005 | 06:47 PM
Well, like I said I don't see any declining oil volume. They are just slightly oil coated so I don't think there is a problem but thanks for the heads up. I also don't see any oil splatter or coating in the engine compartment. It's just on the filters.
