Ok ive got a problem help
Old Apr 4, 2005 | 01:18 AM
Kevs-svt's Avatar
Unhappy Ok ive got a problem help
I installed the mods yesterday and it ran fine with the chip then last night it wouldnt start i would turn over but not start. Also the theft light was blicking. SO i did a search and recleaned the contacts, tried the unlock, lock, unlock, and removing the negative battery cable and turned the head lights on for 15 mins. SO today i started it back up and it worked. I come home tonight and go to start her up and it wont work again. There is a rattle from the fuse box and the Theft light blinks fast. This is wierd it only seems to do this at night. Any help would be priceless
THanks
Kevin
Old Apr 4, 2005 | 02:28 AM
Marc Carpenter's Avatar
Its tired from you driving it all day
On the serious side, did you make sure you did not get any of the comformal coating you removed to install the chip into the PCM?
Sometimes it will flake off and stick in the chip also. Take the chip back out and blow the contact area out with air.
Did you tape the chip in place on the PCM?
Old Apr 4, 2005 | 02:39 AM
Kevs-svt's Avatar
Yes I duck taped. i will take the chip out tommorow and blow it out again just in case. But it only does this at night thats the strange part.
Old Apr 4, 2005 | 01:32 PM
RustySocket's Avatar
Sounds like a bad moon sensor. What codes are you getting?
Old Apr 4, 2005 | 02:34 PM
Kevs-svt's Avatar
What is a bad moon sensor?
Old Apr 4, 2005 | 02:41 PM
D Davis's Avatar
sounds like someones being a joker.
Have you been able to check with Sal at PSP see if he has any ideas?
Old Apr 4, 2005 | 02:48 PM
Kevs-svt's Avatar
no not yet i wanted to see if i could fix it before i bothered him. i will probably be contacting him later today if i cant figure this out.
Old Apr 4, 2005 | 03:16 PM
Kevs-svt's Avatar
ok i think i fixed it i will see later after it sits for awhile. i got in the truck locked the doors with the remote turned the key to on an let it sit for 30 secs or so and it started right up. I think i rebooted the pats on my key i could be wrong thow. But its running as of now.
