Tyre PSI??
Old Apr 4, 2005 | 11:22 PM
l-menace's Avatar
When you running strange engineering racing shocks, you want it soft!
30-32 here.
Old Apr 5, 2005 | 10:35 AM
Tim Skelton's Avatar
30-32 here.
What difference do your shocks make?
Old Apr 5, 2005 | 11:48 AM
RED 92's Avatar
Re: Tyre PSI??
Originally posted by Fowl
On the sidewall of the F1's its suggest 44 PSI max. I just want to know what PSI do you guys run in your F1's as a daily driver. At present I am running 40 all around, but feel a little bouncy.
Let me know your PSI.
"my tires 34 psi"
Base your tire pressure on your tire wear, or on whats comfortable. As a daily driver 40 would be a bit rough.
YA MAN
Old Apr 5, 2005 | 12:11 PM
NTIMD8's Avatar
Originally posted by Tim Skelton
You pathetic pansies. F*ck the sticker. That pressure is for weenies and old women. F1s with 32 pounds feel like marshmallows. If you wanted a Deville, you should have bought one.
Old Apr 5, 2005 | 03:24 PM
RED 92's Avatar
Jesus H Christ. When did you ladies decide to start following the stickers? The sticker says 380 HP. Do you follow that one?
you have to wear a mouth guard to ride in your truck.....
but the bumpy ride makes me have to pee-pee....
Old Apr 5, 2005 | 11:01 PM
Old Apr 6, 2005 | 10:12 AM
NTIMD8's Avatar
You must feel right at home now.
Old Apr 26, 2005 | 04:12 AM
WantALight's Avatar
I recently changed all four of my tires, and I have two extras just in case. At the shop they pumped it up to I think aroun 32psi but it just feels too soft so I put them up to around 40psi.
Before I changed the tires I could see the threads/cord and had to put it to 44psi and in less then a day it would be in the mid 35s. That's what nails and screws all over the place do to your tire! lol
Fowl - I think I may have crossed you the other day. Are there now two DSG and also two Silvers?
Old Apr 26, 2005 | 12:31 PM
99SVT's Avatar
Originally posted by NTIMD8
Sorry the pic is out of focus but I am too lazy to go out and take another one. LOL
Dont all L's have this sticker?
my '99 don't have that sticker
Old Apr 26, 2005 | 05:53 PM
Lightning LA's Avatar
I went with Nitto-555 Extreme ZR's instead of F1's. I think i'm running 35psi all around, they seem to be kinda hard though. My 02 has the sticker and it says 32psi all around. So if it's good enough for the F1's it'll do for my Nitto's. So I may drop them down to 32 and see how they feel.
Old Apr 26, 2005 | 10:44 PM
Robert Francis's Avatar
I've run 42 up front - 40 in rear in my F-1's ever since I've owned my 01L - brand new in June 2001 - no strange wear problems. I also run 38 on the front, 36 in the rear in my 1994 Ranger with no wear problems.
Old Apr 30, 2005 | 02:37 AM
WantALight's Avatar
Similar to what I do...
Do you have any alignment problems ever?
Old Apr 30, 2005 | 11:24 PM
Never had any alignment problems with my L or the Ranger. Almost very vehicle I've owned for the past 40 years, I've run higher tire pressure than most - and never had any alignment problems I felt were due to that. I got my Ranger used with about 60k on it - and I put 60k on it and I never saw any unusual tire wear anywhere on any of the four tires - and I never rotated them either. In fact - I've never rotated tires on any vehicle I've had and I've never had any unusual tire wear - at least up to 40k +. I don't think I've even run a set of tires for over 60k(usually changed about 40k in the past) - so I couldn't say what would happen after that. Every time I've had new tires put on, the wear on them was pretty even( not especially crowned or anything like that) and I always had an alignment job done at the same time - but I really don't know if it was needed - just thought as I was getting new tires and balanced, it was good practice to do. Got the 4WD fixed on the Ranger last summer and they aligned the front end then with about 120k on it - and it's on it's second set of Firestones and they still look good. One thing I do regulary; every two weeks I check tire pressure - and I've found usually one or two tires is down 2-3 lbs - and I pump it back up.
