boost question
Old Apr 2, 2005 | 03:53 PM
lightninquick's Avatar
boost question
will a 75 shot of nitrous incress your boost?
if so how much
Old Apr 2, 2005 | 08:33 PM
Rob_02Lightning's Avatar
No change in my Boost off or on Spray
BUT I DO SEE PLENTY MORE HP AND ET
Old Apr 2, 2005 | 08:34 PM
2000L's Avatar
The nitrous will cool the incoming charge of air making it more dense. Depending on how hot the incoming charge is and how drastic the cooling effect is, I could see causing a slight increase in boost.
Old Apr 2, 2005 | 08:57 PM
the reason i ask is, i have seen and read about head gaskets leaking.
so i really dont want to exceed 22lbs of boost. i drive my L to the tracks i race at. some of them over 400 miles away.
Old Apr 2, 2005 | 09:37 PM
2000L's Avatar
Rick, If you are wanting to run a bigger shot you may want to cut back a couple of pounds on the boost. The gains will probably be greater with the added nitrous over the couple pounds of boost you have to cut back to be safe. Whens the next time you'll be hiting the track? If you still need those tires I might be willing to cut a little more off the price.
Eric
Old Apr 3, 2005 | 12:26 PM
Eric
hey eric april 8th at fontana, me and nosuprise have alittle kiss the hood grudge match
its a private day, so if you havent sighned up you cant race
if you come bring those tires
