QA1 adjustment need help
Old Apr 1, 2005 | 07:05 PM
joecey's Avatar
What is the best way to adjust the fronts. I remeber someone posting a while back that the best adjustment is 7 clicks front and 5 in the back. Whats the best way to get to the fronts? Do I have to lift it up?
Joecey
02
Old Apr 1, 2005 | 07:23 PM
Coldie's Avatar
Adjustment know should be on bottom as far as I know, so just reach in and turn it.
Never had any problem getting to mine.
Old Apr 1, 2005 | 07:25 PM
joecey's Avatar
the back is visible but i've looked at the fronts with my wheels turned and couldnt even see the *****. Are they facing forward or backwords?
Old Apr 1, 2005 | 08:30 PM
Tim Skelton's Avatar
The ***** should be facing inwards.
You reach up and into a hole in the lower control arms.
Be gentle. Turn them all the way back to zero. Then click them back up where you want them.
Old Apr 1, 2005 | 08:41 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Counselor Skelton is correct. The ***** face inward, back to zero, count up, and be gentle.
I usually turn the wheels one to allow for easier access to the adjustment ****.
Bob
Old Apr 4, 2005 | 08:37 PM
joecey's Avatar
Thank you both. I should be at 7 clicks in the front and 5 in the back?
Old Apr 4, 2005 | 08:53 PM
Don's Bolt's Avatar
7 Front 5 rear is just a good average setting for most trucks.
You can play with the adjustments a little to give you the ride and handling you like.
Say if you have a heavy fiberglass toneau you might want to stiffen the rears up a click or two. Or maybee you run different front springs where it might work better at a different setting.
