Alt. output = 37 volts?
Old Mar 29, 2005 | 06:24 PM
teamSLS's Avatar
Hey Guys-
What's up with this?
Did a search (all forums) found very little info regarding high outputs.
Funny thing is, my batteries keep going dead. WTF?
Some background, all things electrical have remained unchanged for at least a year.
Many guages, relocated batteries, stereo, nitrous, methanol, elec h2o pump, elec HE fans, KB BAP, Battery kill switch etc.
I have had a slow drain in the past which I was able to trace but this has me perplexed.
I can hold a charge overnight (when recharged), and batteries do pass a load test.
Anyone?
Thanks,
Andy
Old Mar 29, 2005 | 06:35 PM
B-Man's Avatar
Cool
Sounds like the VR has lost it's reference. Check for poor grounding, worn wire, etc.
Old Mar 30, 2005 | 01:20 AM
clonetek's Avatar
Have the alternator checked ASAP!
Old Mar 30, 2005 | 08:26 AM
yysenhimer's Avatar
Is that 37V checked with no load? Even at no load I think the voltage should only be a coupe of volts higher(like maybe 14.5V). I think these alternators use transistors instead of diodes, and there is a battery sense wire inside it that senses high or low battery voltage, which turns the transistors on or off while running. This is what I was told when I was having issues with the alternator on my boat. Anyway, go to a good shop that specializes in alternators and get it checked out before it blows up.
Old Mar 30, 2005 | 09:47 AM
teamSLS's Avatar
Thanks guys,
I checked the volts to my battery cut off switch and the lead from the alternator is at 37 + volts at idle. However, the switch does not appear to be sending voltage to my batteries.
this leads me to believe one of two things:
My switch is fried or, my switch is fried because of the alternator.
Sooooo, I'm between a rock and a hard place....the cooked switch could be protecting my electrical system right now or it may be the problem!
Any more input?
-Andy
Old Mar 30, 2005 | 10:48 AM
yysenhimer's Avatar
I would order a new switch. In the mean time, take the alternator off the truck and bring it to a good alternator shop. After they fix the alternator, install a new switch before you run it.
Also check out any added electronics to see if they may have caused the problem.
Old Mar 30, 2005 | 07:48 PM
teamSLS's Avatar
yysenhimer and other "helpers"
Thanks again
Did testing of the alternator and associated fuses in the truck, volts ranged between 36 - 43 volts!!!
Did some more testing, finally said f-it and bypassed the switch and.....problem solved! Bad battery cutoff switch.
14.5+- volts at idle with the switch bypassed.
Put the ****** switch in 3 years ago, guess time has taken it's toll on the dam thing.
Soooo, alternator see's that it's not charging anything = major spike in voltage to charge that which is not taking a charge.
Another problem for the search engine
See ya
-Andy
