Crank walk?
Old Mar 28, 2005 | 07:57 PM
ByByBird's Avatar
Crank walk?
How much crank walk to our motors have? I just had a problem when my inspection cover was installed backwards. The tq convertor bolts were barley grazing the cover under real hard loads. I'm figuring that the convertor/flywheel were moving with the crank by about .015. Just enough for a push back cover to meet with the convetor studs.
Old Mar 29, 2005 | 09:14 AM
Blown347Hatch's Avatar
Crankshaft end play in performance motors usually 5-7 thousandths. Your thrust bearing could be wearing.
Old Mar 29, 2005 | 11:24 AM
ByByBird's Avatar
Wow I hope not! It only has 16,000 miles on it!
Old Mar 29, 2005 | 11:33 AM
wydopnthrtl's Avatar
Don't assume all the movement is coming from the crank end play alone. The flywheel will/can flex too.
Rich
Old Mar 29, 2005 | 02:13 PM
ByByBird's Avatar
Rich
That would make more sense. Crank walk + Flexplate movement + Incorrectly installed cover= the problem I had.
