KB = no boost
Old Mar 28, 2005 | 01:20 PM
JeffsLightning's Avatar
Question KB = no boost
Went out today and made a run when something felt wrong. Look at the boost gage and it was reading zero...No boost no vacuum on the gage and the truck runs like *****. The blower belt is still on and when at idle or rpm the KB sounds fine. There was about 6 or 7 oz of supercharger oil that puked out the vent hole on the pulley bolt. It ended up on the plenum and under the hood. Any ideas on what this could be? Coupler? Guss I'll call KB and see what they say...Maybe another KB bites the dust....we will see.. :-(
Old Mar 28, 2005 | 01:41 PM
nineseclightnin's Avatar
Re: KB = no boost
Check to see if your EGR valve is stuck open or if the vac line is melted to the EGR tube. There was one truck here locally that melted the vac line when the egr solenoid commanded it open and it stayed open until the melted part was fixed.
Steve A.
Old Mar 28, 2005 | 01:53 PM
Rob_02Lightning's Avatar
Jeff, do you still hear the Whine ???? Have you been adding alot of SC oil ??? One prob a pal of mine has is when the seal leaks INSIDE the Front Snout. This will send the S/C oil (if you keep adding oil) all over your entire intercooler, "you will lose a lot of power", but that wouldn't explain the loss of Boost ???
Either way sorry to hear it Pal
but as everyone has been pointing out to me, KB has been very very helpful and quick with the repair work. A Lightning recovery to you Jeff.
Old Mar 28, 2005 | 02:05 PM
honda hunter's Avatar
Just my opinion but that's what scares me about the KB. It's cool theyll take care of you (which they should) but its just a pain in the tail to have to go through it all. Good luck.
Old Mar 28, 2005 | 02:11 PM
PROBLEM FIXED.....It was the big vacuum line on the driverside of the blower midplate. It had blown off...KB did not know what it could be but JDM did. I will install a hose clamp on that vacuum line...Guess it could not handle the boost.... Thanks for all your suggestions guys. Glad the KB is still pumping fine
Old Mar 28, 2005 | 02:17 PM
dealerjim's Avatar
Great news. I know that's got to be a huge relief.
Old Mar 28, 2005 | 02:46 PM
Excellent news indeed Jeff, WOO HOO................
Jeff, this was due to the pressure not being taken out, and it spit back right ?
Like those ****** Camels (@#$%@#($%@#($$
hehehehehe
Old Mar 28, 2005 | 04:19 PM
Bob Tompkins's Avatar
Glad you found it Jeff. Mine is parked in my mom's garage till I get the KB back.
Bob
Old Mar 28, 2005 | 07:13 PM
blown318's Avatar
jeff when we goin to the track!!!! I need to get sum passes in the cobra and the truck!!!!!
Old Mar 28, 2005 | 08:53 PM
hehehehehe
Yep I guess so...All is well now
Old Mar 28, 2005 | 08:56 PM
Major relief...I did not want to yank the KB and send it off. I knew KB would take care of it but no one likes the down time. I thought at first it lost the belt but the no vacuum on the gage should have been a tell tale sign to me. Even with no belt you should still see vacuum. That hose that blew off was pretty big... It's hose clamped down now....
Old Mar 28, 2005 | 08:59 PM
Soon....I think I might need more tire though...
