TPS ground
Old Mar 26, 2005 | 08:50 AM
AMP's Avatar
AMP
Question TPS ground
couldn't find the answer searching.
anyone know which wire is the TPS ground? I thought it was gray w/ red tracer, but the truck doesn't run with the digital ground from my wideband connected to it. Just undo the connection (with the digital ground wire (black w/ white)), and the truck runs fine.
Old Mar 26, 2005 | 02:40 PM
JollyGiant's Avatar
The gray/red tracer on the tps is not a true ground. It is a signal return path for the tps and many other sensors.
You need to hook the wbc ground wire black/white to a true ground source.
There is a black wire which is a good ground source in a three wire connector about 2 inches above the diagnostic connector at the bottom right side of the driver side lower dash panel.
Old Mar 26, 2005 | 03:06 PM
AMP's Avatar
AMP
thank you. Is it important then, that the Black w/ white wire is hooked up to a "digital" ground, or just any good ground. When I connect this wire to the same point that I connected the black wire to (an engine ground fastened at the firewall next to the starter selenoid), everything seems to work perfectly. I just wonder why Dynojet would recommend a different grounding point for two wires both intended for ground.
If you can explain, I would greatly appreciate it. I'm just curious.
thanks, Aaron
Old Mar 26, 2005 | 03:52 PM
JollyGiant's Avatar
I don't know why they specify a "digital ground" but a regular ground works fine.
