Help! IAC and oil or something?!?
Old Mar 23, 2005 | 10:50 AM
halcyon's Avatar
Unhappy Help! IAC and oil or something?!?
Well my IAC was clogged or stuck agian, for the 3rd time in 6 months.........made me an hour late to work.
This time the truck shook more violently than any of the other times. I cleaned it out pretty quickly.
When I took the IAC off it was oily. I think it was oil. And the 2 holes that the IAC bolts into had a substance inside as well. I may have sprayed too much WD 40 into the IAC last time and thats what the substance is.?.?
..........not sure what to do
Should I do one of the "no oil in the intake" mods? If so, what seems to work the best for you all?
Old Mar 23, 2005 | 02:52 PM
wydopnthrtl's Avatar
Well... I see you have a 99 and nothings been done for this "issue".
If I had your truck I'd:
Take the I/C out and clean it with about 5-10 cans of carb cleaner. (it's under the blower)
Clean the throttle body really good.
Replace the IAC valve with a new one.
And get a "seperator" (I have a REM unit)
Put it all back together and you should be good to go.
SHould only cost about $40 total and I'm perty sure your gonna look like this when you see the I/C.
Rich
Old Mar 23, 2005 | 03:25 PM
halcyon's Avatar
Yeah, I planned on taking apart and cleaning those exact parts.
Ive seen the pics and know that mine will be really bad. I need to do the leaky I/C fix at the same time too.
Right now i'm more concerned with the oill in the intake thing. What options do i have, some people plug them right? or use breathers.
what is the REM unit, who sells that?
thanks man.
Old Mar 23, 2005 | 03:38 PM
halcyon's Avatar
...........just ordered the REM seperator.
