Which Is The Best Plug For Our Built Motors
Re: Which Is The Best Plug For Our Built Motors
Originally posted by tlfwatch
Which plug works best for our built motors for our lightning s denso's it- 22's or ngk tr6's thanks
I run TR6's gapped at .034 and have been pleased. I broke an electrode off a Denso once while trying to gap it so I yanked the other 3 I had already installed and threw the rest of them in the garbage. The NGK's do a great job and are waaaaaay less expensive than the Denso's.
My HP, my times(both are sub what it really is doing) on a stock block; always on Denso's IT22's Only EVER slightly melted the tip of one due to running very low fuel and starving it for fuel on a hard take off. But, what do I know
You want the widest gap possible without spark blowout. I haven't had any problems with .034 but that's not to say others wouldn't. It was basically a trial and error thing with me. I started with .036 and had blowout, then .035, etc. until the problem was gone.
I haven't had any experience with the BR7's but if I'm not mistaken the high boost guys with nitrous are running those.
On my race program I run 19psi boost w/ no nitrous and the TR6's fit the bill just fine.
I refuse to pay nearly $11 per plug when I can get the NGK's for $1.50 each. JL could've just as easily ran that 9.8 with NGK's.
BR7EF is the exact same plug I have in my Honda Snowblower.
I run Denso IT-20 with my 4lb with no issues for over 25K. Runs smooth as silk. Toyota uses Denso in all their twin cam applications from factory.
I will change to IT-22 when I increase to 6lb. Yes they are more money but they burn very efficiently.
IMO
TB
IMO
TB
