I need to trailer a 2004 Lightning
Old Mar 16, 2005 | 11:06 AM
genovet's Avatar
I'm buying a 2004 Lightning and need to trailer it home which is about 300 miles. I'm hoping that someone has trailered their Lightning and can tell me how wide the trailer must be between the fenders. Unfortunately, I don't know anyone local with a Lightning. Thanks in advance for the help.
Old Mar 16, 2005 | 11:11 AM
l-menace's Avatar
ummm... Welcome to the club and WHERE ARE YOU?
Old Mar 16, 2005 | 11:17 AM
HIGH VOLTAGE's Avatar
Welcome Your new L is 208 in. long, 70.9 in high and 79.1 in. Wide. Good luck
Old Mar 16, 2005 | 11:31 AM
genovet's Avatar
Is the 79.1" width from the outside of the tires? If not, what is that measurement?
Thanks for the welcoming me to the club. I'm located in Southern NJ.
I bought the Lightning to pull my 1985 Mustang drag car. I went back and forth between buying a Lightning or a Silverado SS but I finally decided on the Lightning. A Lightning towing a Mustang drag car seems to be a bit more appropriate than using a Silverado. I doubt anyone will disagree with me on this board.
Tim
Old Mar 16, 2005 | 11:51 AM
tommylightning's Avatar
I am also in southern NJ let me know if I can help you. Also have a trailer I can either let you use or can help you with. Email me @ tommylightning@outrageousperf.com
Dman25's Avatar
Tim
Haha... not only do i agree, but the L has much more performance than the SS. If you wanted more passenger capacity and towing capcity SS is the way to go, but for what u need the L is perfect and fast! enjoy it!
Old Mar 16, 2005 | 11:56 AM
oh2red's Avatar
I towed my 02 L from Knoxville to New Orleans useing a rented trailer from U-Haul. It worked great and I didn't have any problems.
Old Mar 16, 2005 | 01:26 PM
buckstop515's Avatar
my trailer is 85" btw the fenders. that leaves about 1-2"of bed left on each side. the biggest problem I encountered is positioning the truck so all the weight isn't on the tongue. My trailer is 18' with a 2' dove tail for a total 20'. cross your straps and pull on.
Old Mar 16, 2005 | 01:31 PM
philosophico's Avatar
Question? Why dont you just drive it home?
Old Mar 16, 2005 | 01:51 PM
genovet's Avatar
Driving the Lightning home is an option but I was trying to avoid that so I wouldn't need to take a second person with me. Unfortunately, my trailer that I use for my drag car is only 74" between the fenders which is way too narrow. The seller of the Lightning offered to sell me his trailer but the width between the fenders is 77" which I believe will not be enough. He is taking measurements this afternoon but I thought it wise to get some advice from all of you as well. Thank you very much.
Old Mar 16, 2005 | 03:53 PM
skinny fronts might get you on
Old Mar 16, 2005 | 05:01 PM
genovet's Avatar
Tommylightning offered me his trailer to use free of charge...what a great guy!
I plan on getting the Lightning on Friday.
Thanks Tom.
Old Mar 16, 2005 | 08:03 PM
White01's Avatar
When I blew my motor last year, I had to put my truck on a 6ft wide trailor. It fit BARELY! The front tires rubbed up through the fender wells and the exhaust pipes just about hit them also. I also had my 20's on the front. I also had to pull the truck on the trailor with a come-along. Good luck
Rich
Old Mar 16, 2005 | 08:54 PM
FunTruck's Avatar
Here's how I towed my 02. Went about 700 miles. My Chevy has the 5.7L. I also installed some AirLift airbags in the rear. I inflated them to about 90psi.
I guestimate that I was pulling about 7000lbs. It drove just fine even though I never went above 65mph with it.
Some kind of Trailer Brakes are a MUSTas well as some sort of load leveling IMO.
I don't see why the Lightning wouldn't fit on most car trailers mine fit like a glove.
Old Mar 16, 2005 | 09:18 PM
qwikcobrazj's Avatar
whoa,whoa, there. Let me straighten this out, it should read
If you wanted more passenger capacity and towing capcity 02-03HarleySupercrew is the way to go
