Finally found Adjustable Upper Control Arms
Old Mar 11, 2005 | 11:24 AM
TampaBlack99's Avatar
Chassis Tech sells them.
Old Mar 11, 2005 | 11:33 AM
Konig's Avatar
Chassis Tech? I thought they made junk parts?
Old Mar 11, 2005 | 11:35 AM
It's the only adjustable upper I can find right now. The oem upper is already a thin piece of metal. This has got to be strong, it's adjustable and comes with urethane bushings. It also looks like switching out the ball joints is simple.
Old Mar 11, 2005 | 11:43 AM
Tim Skelton's Avatar
Why do you want the adjustability, Tampa?
Old Mar 11, 2005 | 12:02 PM
Casey02L's Avatar
Wonder if that lower is any lighter than stock?
Old Mar 11, 2005 | 12:08 PM
To push the top of the wheel further out and stop the wear on the inside of my tires. The cam kit only does so much.
Old Mar 11, 2005 | 12:29 PM
How much and where? I have about 2 degrees of negative camber and the alignment guy said that this was the best that he could do.
But note that Stan Martin says that if the caster is set a certain way, then the camber can be done within specs.
Old Mar 11, 2005 | 12:42 PM
Master Of Pain's Avatar
What is the weight of this kit? All I care about is reducing unsprung weight.
Old Mar 11, 2005 | 01:07 PM
How much and where?
The upper's cost $299 and can be purchases here (I'm sure another place might be cheaper),
http://www.truckn-store.com/product....D1%26ID%3D1855
SKU#: CAR-FO97XX-3
$299
