tranny
Old Mar 9, 2005 | 02:49 AM
dr408's Avatar
tranny
i have a 00 lightning and ive been noticing when i get in it (wot),when it shifts two 2nd, it momentarly bogs,then picks right back up,anyone ever had this to happen to them
Old Mar 9, 2005 | 06:26 AM
ByByBird's Avatar
Tq reduction! Do a search for it. It's normal.
Old Mar 9, 2005 | 06:11 PM
dr408's Avatar
come on guys, post up,,
Old Mar 9, 2005 | 07:10 PM
WaveBlaster785's Avatar
Look above.
He already told you what it was.
During the 1-2 shift the engine shuts down a couple cylinders, or fuel, to reduce the amount of torque going to the tranny and tires.
Search is your friend as mentioned before chief.
Copy and paste: "Torque Reduction" to the search menu
Old Mar 9, 2005 | 07:14 PM
SVT F15O's Avatar
Transmission could also be slipping. Could have what is known as a "slide bump" happening on the 1-2. Vehicle will kinda nose over on the shift while the clutches are slipping before they grab. -Mat-
Old Mar 9, 2005 | 11:26 PM
dr408's Avatar
thanx fo rthe reply's, im doing my homework..
Old Mar 10, 2005 | 02:10 AM
Factory_Tech's Avatar
I doubt it, sounds to me like torque reduction. If a clutch is gonna slip like that, it will do it all the time, or it will slip all the way through a gear until the next gear. An engagement slip will slide on what's called the engage regression (slipping until they grab, they have converging lines on a graph where the output torque will slope downwards as the engagement pressure and input torque increase, they stabilize when the input torque settles) but it will also throw a code to the PCM most of the time. Anyhow, I'd really have to know more than what you wrote to tell for sure, but what you're describing screams "Torque Reduction" to me.
G
Old Mar 10, 2005 | 08:20 AM
SVT F15O's Avatar
G
I agree with the torque reduction bit but he didn't want to buy it. So I threw out another option. Also if you have never experienced a slide bump before I think you need to get out a little more in the transmission industry. -Mat-
Old Mar 10, 2005 | 06:20 PM
dr408's Avatar
No, i bought it but second,thrid,fouth,ect opions dont hurt, i wanted more post to see how many different and how many of the same anwsers., i dont know crap about automatic trannys, and if thats what you were talking about you were right but if you throw a tremec,T-5, T-45 on me i will educate anyone on this board on that.,,,,thanx for all the replys, you guys helped me out..
