JLP shackles on regular F150
Old Mar 8, 2005 | 09:02 PM
Bartak1's Avatar
Ok, the only 3" shackles I can find are the JLP ones. Im getting them for a regular F150 (non L) and Ive read that the L and regular 150 rear suspension is about the same, so these shackles should work on my truck, correct?
If so, are you guys using these getting a full 3" drop, and is there much travel left with the stock length shocks? Anyone used/using stock length shocks with these shackles? If so does it work very good?
Thanks guys
Old Mar 8, 2005 | 09:23 PM
cerucker's Avatar
It will work. I did the same thing. The Lightning uses different springs, but the shackle mounts are the same. The shocks are staggered, so the effect would be minimal. I am using stock length Bilsteins.
Hope this helps!
Old Mar 9, 2005 | 03:08 PM
Bartak1's Avatar
Helps a ton. Thanks
