Pinion Angle and Rancho Trac Bars
Old Mar 5, 2005 | 11:24 AM
whitebolt01's Avatar
I have an 04 and have jlp drop shackles and trac bars. I flipped the shim for my 04, still had a vibration, then I removed the shim.
My question is if my pinion angle was off before I installed the trac bars, would it still be off if I removed the shim? If I remove the trac bars would anything happen to the pinion angle? Also, can someone post a pic of how a 2 degree negative pinion angle should look.
Thanks,
Simon
Old Mar 5, 2005 | 07:12 PM
https://www.f150online.com/galleries...w.cfm?num=7594
A few pics I took, will try to get some better ones tomorrow.
Old Mar 6, 2005 | 12:48 PM
ttt
Old Mar 6, 2005 | 02:06 PM
svt_2004's Avatar
looks ok from the pics man
Old Mar 6, 2005 | 02:13 PM
I am gonna get out there today and measure the angle.
Old Mar 6, 2005 | 02:22 PM
svt_2004's Avatar
Tranny (yolk) = 4 degrees
Driveshaft angle = 2 degrees
rear end (yolk) = 4 degrees
and i was told to subtract all the angles
4 - 2 - 4 = -2 (negative 2 degrees)
i hope thats right
Old Mar 6, 2005 | 02:23 PM
svt_2004's Avatar
the only thing that concerns me is that the rear end (nose) isnt angled down, i dunno if that matters or not
Old Mar 6, 2005 | 02:30 PM
Thats my main concern. I will try and get under there today and will post later on.
Old Mar 6, 2005 | 02:33 PM
svt_2004's Avatar
anyone else comment on this?
Old Mar 6, 2005 | 04:48 PM
Took some measurements.
Tranny yolk=4 degrees
Driveshaft angle=4 degrees
Pinion yolk= +2 degrees
What do I need to do?
If I do your calculations then I get a +2 pinion angle. So do I need a 4 degree shim?
Old Mar 7, 2005 | 01:14 AM
svt_2004's Avatar
i really wish someone would chime in on this, i think you should be ok with what you have. And not adding any shims.
I mean if you have no vibrations, and since you have tractions bars i wouldnt worry about anything, from you pics every thing looks ok to the naked eye
Old Mar 7, 2005 | 08:38 AM
My only problem is the pinion is pointed up a little.
Any one else have any ideas?
Old Mar 7, 2005 | 10:14 AM
svt_2004's Avatar
mine points up a slight bit to, i wouldnt really worry about it, bu t then again thats me.
Hope someone can fill us in
Old Mar 7, 2005 | 04:12 PM
Anyone else got any advice for me?
Old Mar 8, 2005 | 01:12 AM
svt_2004's Avatar
ttt
