500 + RWHP, what has to be done!!
I have the following, 01 Lightning with these mods
4lb lower pulley
Accufab TB
Exhaust
Intake
Custom Chip by Xtreme Motorsports adjustable
PRT Stage III transmission
PRT Converter
I want 500+ RWHP, I will not use NOS. This truck will be daily driven. Please let me know what needs to be done..
4lb lower pulley
Accufab TB
Exhaust
Intake
PRT Converter
MAGNUM POWERS!
With 50# injectors and a SCT Maf
Also when you say exhaust do you mean headers,etc....
I would do a electric fan, maybe a C&L plenum, phenolic spacer, NGK TR6 plugs gapped around .032"-.034" along with.
I would highly recommend a Dyno tune afterwards.
We run the truck to about 465 -470 on a street tune and 490-500 is well in range with race fuel.
Remember at this point you are reaching or at the limits of your stock internals (rods,pistons,etc...)
Hope this helps
JimIII@JDM
Hope this helps
JimIII@JDM
If you have a full exhaust(headers) get yourself a KB; run about 16~17#'s of boost, 60#'s injectors and a SCT maf and a dyno tune. The tune can be setup rich and safe(lower timing), and can be run on pump gas everyday.
Just my opinion, but since I have ran every form of blower on my truck I think I have a good idea......
I just ordered the Kenne Bell today
So I take it that I need injectors?? Who should I get them from? What will the truck run in the 1/4 mile? I want 10's or 11's, will this get me there? Slicks of course
JimIII
Originally posted by JimIII@jdm
Should get you to mid to high 11's. 10's require a built motor.I would go with 60# injectors we have them here for $465. Also a SCT maf would be suggested and tune. Dont run more than 17 psi or your asking for trouble with the KB. I wouldnt run more than 15 psi. Also get it on a dyno and have it tuned.
JimIII
JimIII
I was already to build with you and then I couldn't get a straight answer on total costs and I couldn't risk agreeing on one number and then having to come up with more when it's done... I was already to ship my truck.
Originally posted by 35thPony
Jim when I called I was quoted $595, any reason for the confussion... I also was quoted differently on a short block installed with heads and cams work on the two times I called and I mean like $1000 different...
Im sorry for the confusion with your quote on the motor. Motor jobs are pretty indepth so sometimes the quote is off a little. Next time just ask for me or Anthony we deal with these jobs everyday and can get pretty accurate for you.
The injectors we just recently were able to drop the price. They were $570 now they are $465. Also the SCT Maf we dropped from $325 to $275.
JimIII
Originally posted by Falcon11
Casey02L,
What are your 1/4 mile times? slicks? streets?
Casey02L,
My 1/8ths have been in the 7.3 range; still havn't got any really good passes. The truck has an honest 7.2 in it; maybe a 7.1 when I step it up a little. That should make for some mid to low 11's
Originally posted by Casey02L
We don't have any 1/4 mile tracks in this area
What size pulley you running with that stock block?
The truck has a lot of street racing miles on it too
