JLP traction bar install?
Old Feb 28, 2005 | 05:14 PM
Bob Tompkins's Avatar
I have rounded up the missing hardware and I am going over the instructions and I am unclear on one thing.
#13 states Prior to drilling the horizontal holes in the frame, use the floor jack to raise the passenger side of the vehicle and place on a jackstand"
Im not totally sure why I need to do this? Do I need to keep the pass side jacked up while doing both sides?
Bob
Old Feb 28, 2005 | 05:19 PM
JeffsLightning's Avatar
Me either. You just want to make sure the suspension is loaded equally on both sides before doing any drilling for the front brackets. I drilled the vertical holes first then used the bracket as a template for the horizontal holes...Just be careful on the driverside because of fuel lines and the fuel tank. I used a small piece of plate steel as a backstop for when I was drilling on the driverside....
Old Feb 28, 2005 | 06:29 PM
B-Man's Avatar
Cool
Here's the write-up I originally did on the JLP bars...
Old Feb 28, 2005 | 06:50 PM
Thanks Jeff and B-Man!!!
I printed that out.
