World Products Aluminum 5.4 Blocks
Re: World Products Aluminum 5.4 Blocks
Originally posted by SVTJAY
Summit Racing -World Products 5.4 Aluminum Block
$4695.95 - Wow thats expensive!
Definitely is interesting though. I just got a new WP catalog and don't recall seeing that in there.
Re: Re: World Products Aluminum 5.4 Blocks
Originally posted by LightningTuner
Not really, that's an average price for an aftermarket aluminum block.
Sal I have been emailing you for the past few weeks but have not received a response. Is there a better way to get a hold of you?
Thanks, Jason
Re: Re: Re: World Products Aluminum 5.4 Blocks
Originally posted by NTIMD8
Sorry for the hijack!!
Thanks, Jason
Thanks, Jason
Re: Re: Re: Re: World Products Aluminum 5.4 Blocks
Give us a call and leave a message and Lisa will call you back towards the end of the day. I am usually always backed up on e-mails, especcially the past few weeks, because we've had a huge rush of nonstop shop work.
EDIT: Thanks for the rely on the email Sal. I sent a reply and also gave Lisa a call. When I hear back from her I will put the order through. Thanks!
This is the end of the post hijack! Sorry!!!! :o
Thanks, Jason
SHP
Theres more to it than just weight. The bigger bore adds a lot of breathing room to the cylinder heads and the bores are a lot stiffer. The bores in a stock iron block start to move around a lot as the power goes up.
On a side note...I just got the Darton MID sleeves in the mail yesturday and the thrust faces are around .300 thick
and the sleeves are made from a much better material. Cant wait to get this thing to the machine shop.
Dale
and the sleeves are made from a much better material. Cant wait to get this thing to the machine shop.Dale
Also you could stare at this for a little while. http://www.karkraft.com/bare_blocks.htm
This block has to be sleeved to get the larger bore and with the other machine work involved could equal or exceed the price of the WP block.
Dale
Dale
JL
