TR6 Good Plug?
Old Feb 22, 2005 | 07:17 PM
OCSSleeper's Avatar
TR6 Good Plug?
Are these good plugs to run or do i need a colder plug? What Im asking if this is a good heat range?
Old Feb 22, 2005 | 07:52 PM
LIGHTNINROD's Avatar
For 4 lbs or less over stock boost.
Dan
Old Feb 22, 2005 | 08:57 PM
jarmstro's Avatar
Post
TR-6s work great on a 8lb lower with a 2lb upper also...
Old Feb 23, 2005 | 12:29 AM
OCSSleeper's Avatar
I'll be running about 5 or 6#'s over stock> Should I go colder what is the next step colder? I know that they make TR7 Anything inbetween?
Old Feb 23, 2005 | 04:18 PM
NorCalLightning's Avatar
NGK BR7EF's are what I'm running with my 4 lb pulley and ported eaton. It runs like a champ. Just gap them between .032 to .034 and you'll be fine (what PSP recommends).
Steve
Old Feb 23, 2005 | 04:26 PM
iceman302's Avatar
Steve-
It appears you've been busy.... When were you planning on telling me.... before or after you smoked me off a light?
Old Feb 23, 2005 | 04:53 PM
Originally posted by iceman302
Steve-
Old Feb 23, 2005 | 06:52 PM
2bscrewed's Avatar
I run tr-6's gapped at a conservative .030 and I run between 15-18#'s of boost. They have been in for 10k miles like that and I have had zero problems and am still running the same plugs.
Old Feb 23, 2005 | 07:38 PM
smokingozzy's Avatar
I run Tr-6s gapped @.32 with a 4# lower 2# upper, Ported Eaton and a 50 to a 75 shot of Nitrous!!! Jim
Old Feb 23, 2005 | 11:14 PM
LatemodelRacer2's Avatar
I run tr6's @ .034 with a 4lb lower 2lb upper ported eaton and a 50-75 shot on 93 octane
Old Feb 24, 2005 | 09:22 AM
Blown347Hatch's Avatar
NGK TR8IX (iridiums) here, gapped at .035
Smooth idle.
