How easy is it to put in a FTVB?
Old Feb 17, 2005 | 06:41 PM
OCSSleeper's Avatar
Now I'm seriously considering this mod, but may have to swap it back out for warranty reason. So how hard is it to do. I'm pretty mechanically inclined, or atleast I can do almost anything but port heads and build a bottom end, as far as trannys go I can only take them out, replace clutches, and fluid. Will I be able to install a FTVB. Keep in mind I've never even done a shift kit before. Also are there any sites or links you all could throw at me for a little guidance? Thanks!
P.S. Where do I get a good deal on one?
Old Feb 17, 2005 | 06:46 PM
72smitty's Avatar
Installing a FTVB is a piece of cake. I got mine from PSP (same one made by Gregg) and it came with easy to follow instructions. You might want to go ahead and order a deep trans pan with a drain plug and new filter while you're at it. I'm sure anyone that sells them includes instructions. It only took me about an hour and I'm not the most mechanically minded individual.
Old Feb 17, 2005 | 07:38 PM
Rob_02Lightning's Avatar
I got a good Step by Step with Pictures
http://www.lightningrodder.com/forum...hp?topic=119.0
PIECE OF CAKE JOB
PSP and Chicken Man should have FTVB's in stock
http://www.powersurgeperformance.net...products_id=36
http://www.chickenears.com/accumulator_main.htm
Old Feb 17, 2005 | 08:50 PM
jboss10's Avatar
PIECE OF CAKE JOB
I think I did it in about 30 minutes..just because that's how long it took to drain all the old fluid out. I also had the truck over my head...made it a lot easier.
Old Feb 17, 2005 | 10:27 PM
WA 2 FST's Avatar
I've done 4. If you can pull the trans pan, you can install the FTVB.
Old Feb 17, 2005 | 10:46 PM
RustySocket's Avatar
It's a real easy mod. You need a torque wrench that reads in in/lb and some rags.
Old Feb 18, 2005 | 12:26 AM
cteselle's Avatar
It's pretty easy, just a big mess.
Old Feb 18, 2005 | 03:54 AM
OCSSleeper's Avatar
Thanks Guys!
Old Feb 18, 2005 | 07:02 AM
AZ fun's Avatar
Don't get ahead of yourself and pull the wrong one. Several have done so..
Old Feb 18, 2005 | 08:56 AM
Chikenears's Avatar
OCSSleeper,
Like everybody said, it's a snap to install. I have them in stock and will ship today.
Thanks,
Tim@Chikenears
Old Feb 18, 2005 | 12:22 PM
54Triton's Avatar
very easy! I did it this past weekend to my Harley and i had never messed with a transmission before. Had it done within an hour and a half.
