Plugs
Old Feb 16, 2005 | 07:03 PM
Fowl's Avatar
Plugs
Hey Guys,
I just received my 4lb pulley, AF1 filter, 4bank chip, line valve mod and plugs. My truck will arrive on tuesday.
A friend of mine and myself are going to do the mods except the plugs, which I will have a mechanic install.
My question is: How long can I drive the truck after installing the mods before I have the olugs put in?
Old Feb 16, 2005 | 07:22 PM
Don's Bolt's Avatar
You should be OK for a while
Which plugs did you get??
Old Feb 16, 2005 | 07:26 PM
Fowl's Avatar
Denso IT20's. I was a bit worried that it might cause damage on the stock plugs.The ford dealer is packed with work and they want US$220 to change them. I spoke to a reputable mechanic and her said it would take about an hour and his cost is $60.
Old Feb 16, 2005 | 08:03 PM
Fowl's Avatar
Don's Bolt is there something wrong with IT20's on a 4 lber?
Old Feb 16, 2005 | 08:22 PM
Don's Bolt's Avatar
A lot of guys use them, so I would say you would be fine with them. I have never used them myself, so can't give you any first had knowledge about them.
Old Feb 16, 2005 | 08:26 PM
Yeller916's Avatar
only an hour to install? 60 bucks? i would have gladly paid that....every shop around me wanted 240 so i just ended up doin it myself
Old Feb 16, 2005 | 09:57 PM
evo's Avatar
evo
I've had the IT 20's on for about a year with plenty of trips down the 1320 with no problems.
I'm switching to Autolite AR94's just to give them a try. A lot cheaper than the Denso's.
Old Feb 16, 2005 | 10:27 PM
Fowl's Avatar
A lot cheaper than the Denso's Yep the Denso's cost $80 for the 8.
Old Feb 16, 2005 | 11:49 PM
Blown347Hatch's Avatar
I ran the factory stock plugs with a 6lb lower and Predator and JLP Cold Air Kit for 6 months, no problem.
Put cold plugs in, and couldn't get away with any more timing than I could with the stock "hot" plugs.
Old Feb 17, 2005 | 07:21 AM
evo's Avatar
evo
Did you change the gap?
Old Feb 17, 2005 | 09:26 AM
.035
Old Feb 17, 2005 | 11:55 AM
Fowl's Avatar
GAP??
What do you guys suggest I gap my IT20' at with the 4 lb lower? .50?
Old Feb 17, 2005 | 10:00 PM
Re: GAP??
.032-.035
Old Feb 18, 2005 | 09:08 AM
brahmus's Avatar
This is Tampablack99's chart i don't know if he ever finished it but this gives you an idea!! I'm running the IT22 with a 4lb lower and apten port. leaves me room to upgrade
Old Feb 19, 2005 | 05:34 PM
Fowl's Avatar
My tuner suggested .50 and you guys say .36-.38 so I guess I might be safest with .40?
