8# lower?
Old Feb 15, 2005 | 10:51 PM
BlueSVT's Avatar
8# lower?
Im searching for what kind of lower i should get and i found an 8# that i will prob end up getting but i was seeing if anyone else was running with one and if so how you like it?
Old Feb 15, 2005 | 11:00 PM
Blown347Hatch's Avatar
Probably most will tell you that you would be over spinning/overheating the blower. You'll make a lot of low end torque, but you may want to consider lowering your shift points to 4800 RPM. I'd also make sure your A/F is 11.5 or lower, and timing probably no more than 15 degrees (or less) at WOT.
You may end up having to detune your vehicle enough that in the end you're trading HP in the detuning process.
Old Feb 15, 2005 | 11:02 PM
Suavy's Avatar
Live on the edge go 16 lb lower!
Old Feb 15, 2005 | 11:06 PM
BlueSVT's Avatar
haha thanks but no thanks i found one that seems to be good it has the cage like the stock one incase something happens i can swap it out no problem (hopefully the guys tuning it will get it right) its made by jdm my boss had it on his harley truck and he was putting down 416rwhp w/ it
Old Feb 15, 2005 | 11:17 PM
Make torque like a diesel: 650ft/lbs at 1200 RPM with that thing.
Old Feb 16, 2005 | 12:06 AM
l-menace's Avatar
On a stock engine, 6# is pushing it.
If you go 8#, you MUST change your plugs, and MUST have it dyno tuned.
I wouldn't put a 8# on mine if someone gave it to me.
I'm happy with my 'lil 6# and ported blower.
Old Feb 16, 2005 | 12:23 AM
St Louis Lightning's Avatar
I have the same setup as you. I talked to Sal about stepping up to an 8lb and his response was maybe if you do LT headers. Well it just so happens that I am doing that and hi-flow cats so maybe I'll give it a shot.
-Mark
Old Feb 16, 2005 | 12:40 AM
lightninquick's Avatar
i have ran the 8lber a few times. it gets in the boost alot quicker
not real sure what the gains were against the 6lber in the 1/4
Old Feb 16, 2005 | 12:05 PM
moses Black 01''s Avatar
I liked my 8#, but i couldnt tell as much of a difference as i thought i should. Also this may be couincidence, but my blower took a dump about 5k miles later. What the heck though now ill just get a screw.
Old Feb 16, 2005 | 03:57 PM
BlueSVT's Avatar
this is the one i was considering [IMG]picLHE-JDM8lbRingNcage01.jpg[/IMG] or not cant get it to work
Old Feb 16, 2005 | 09:26 PM
rainman15's Avatar
Its
Old Feb 16, 2005 | 11:32 PM
one more thing to think about is the fuel you have available
91 octane from california dont chance it
if you got 92 to 94 then heck yeah
Old Feb 17, 2005 | 06:07 PM
Fast Gator's Avatar
I started out with a 2 lber, when that was living dangerously.....
jumped to a 4lber,
then switched to a 6lber,
made the move to an 8lber........
Couple things to remember
I always get a dyno tune when switching pulleys, I run the full exhaust (Long tubes, hi-flow cats, Bassani) and never do those 55mph kickdowns.
Think I'll go bigger this time
