Another oil separator observation....
Old Feb 15, 2005 | 01:47 AM
Blown347Hatch's Avatar
Unhappy Another oil separator observation....
I have the Campbell Hausfeld separator on my truck. The first day, it filled 1/4 of the way in just a few miles. Then after that, it seemed to stop filling up. I read that the center hung filter gets plugged and stops flow. So I drilled a hole in the bottom center of the filter.
Tonight, I shined a flashlight on it while the truck was running, and it looks like oil is swirling around in there, but not collecting and filling up. What gives?
I tried taking the center filter out all together, and it seemed to stop the swirling, but I didn't seem to be collecting anything either.
Are some separators better (different?) than others? Any ideas to make it collect oil?
Old Feb 15, 2005 | 02:23 AM
onebadf150's Avatar
Them only one to go with is an L&S oil seperator check out the NHTOC.com or The NLOC.net in the supporting vendor section the guys name is Vince he's a super nice guy the PH# 225-756-8488 his shop is in Baton Rouge, LA
Old Feb 15, 2005 | 09:47 AM
fullboogie's Avatar
I installed the same filter about 3 weeks ago, and the same thing happened. About a teaspoon of oil went in immediately, then nothing since then. Weird.
Old Feb 15, 2005 | 10:20 AM
wydopnthrtl's Avatar
Is your filter element for oil? There is a difference between a water seperator and a oil seperator.
Just asking the question in case you did'nt know..
Rich
Old Feb 15, 2005 | 10:30 AM
Rich
This is what the description was:
The MP5138, mini general purpose filter protect tools and equipment by removing most solid and liquid contaminants. This may include dust, dirt, pipe scale, rust, liquid water and bulk oil. A 5-micron filter element removes the smallest of particles. See-through bowl allows easy monitoring of fluid level. Features a manual drain and screw-on bowl. Mini series provides up to 21 SCFM flow capacity at 90 PSI. 150 PSI maximum pressure. 1/4-inch female NPT ports.
Old Feb 15, 2005 | 10:53 AM
RED 92's Avatar
pull your supercharger and see the oil in your intercooler.......then post back. Nice guy or not, separator or not... if the crankcase is part of your intake system your getting oil.
