quick help plz, ground effect repair
Old Feb 14, 2005 | 01:25 PM
Silverstanger's Avatar
OK.. on the ground effect After the driver's door the vertical part of it that goes up is splitting off.
It's still together but is splitting at the corner.
I want to save it while I can and I have it prepped for repair now.
What do you guys know that I can put in the INSIDE to join the two corners together strong.
I don't know what material the ground effects are made out of.
Also under the black paint there is red color.. could this be a sign of a previous owner wreck?? On the back there is hints of red but was black sprayed over.. doesn't look like a fix job but I don't know what color the ground effects are originally before they are painted.
Thx for help in advance..
Old Feb 14, 2005 | 03:52 PM
wydopnthrtl's Avatar
Thoughly scuff the back side with 60 grit. Then use a little fiberglass resin with a small patch of glass mat.
If it's seperating? Then you'll want to apply pressure to hold the crack closed for a few hours while it's drying.
Let it dry good and then sand & grind any edges that might be visible from the outside of the truck.
It's easy and cheap, Rich
