When to add traction bars?
Old Feb 14, 2005 | 09:12 AM
g-divisionboyz's Avatar
I was wondering when to add a traction bar set-up for our L's?
I am currently running just stock but will add a stage 1 by the end of this week. Stage 1= CAI, 4# pulley, SCT tuned, and dyno.
oh and I will install a set of Nitto 555 (Non Drag tires) today. I noticed many L's I read had traction problem and wanted to see when I should add a traction bar set-up to my L's.
By the way, My L is a daily driven.
Old Feb 14, 2005 | 09:59 AM
ZEM'S04 L's Avatar
now!
Old Feb 14, 2005 | 10:14 AM
svtpete's Avatar
I just put some jlp lift bars on this weekend and i love them. I broke my drive shaft recently do to bad wheel hop. There is no more wheel hop.
Old Feb 14, 2005 | 12:04 PM
D Davis's Avatar
Re: When to add traction bars?
the reason for traction bars on our trucks, is to stop the wheel hop & axle warp when it hooks, failure to have traction bars has broken a few driveshafts. just start with a set of slapper bars such as Lakewoods, etc. they're inexpensive and will save your driveshaft, also they should be fine for your mods.
IMO, I doubt the non drag radials will help you much on traction
Good luck and happy modding
Denny
Old Feb 14, 2005 | 12:48 PM
69aries's Avatar
The time to do it is the minute you add drag radials or slicks.
Old Feb 14, 2005 | 02:00 PM
Tim Skelton's Avatar
They should have been on from the factory.
Old Feb 14, 2005 | 02:21 PM
evo's Avatar
evo
I second that.
Old Feb 14, 2005 | 03:00 PM
wydopnthrtl's Avatar
IMO the way it came from the factory is just fine.
You'll need bars when: You significantly firm up the shifts and/or get sticky tires.
Old Feb 14, 2005 | 03:28 PM
unclemole's Avatar
As a daily-driver, I added slapper bars at the same time as the FTVB, chip and pulley, etc. It should be in the intial mods. What's power without traction? Smoke.
